Help acceleration
  • Thread starter jeffreydim
hello,
find velocity required to keep an object in moon's orbit? so far, a = velocity squared over radius and force equals g constant times mass 1 times mass 2 over radius squared, but the object's mass is not given and mass of moon can be found, any help?
Answers and Replies
G01
HINT: You already know that:
[tex]F_g = \frac{GMm}{r^2}[/tex]
But what else is this equal to. What kind of motion is the object in if it is in orbit? You should be able to set the above expression equal to another expression involving m, then the m's should cancel. See how far you can now. Good Luck.
The thing is, it is independent of mass of the object. This is essentially what Galileo demonstrated nearly 400 years ago.
Calculate escape velocity, cancelling the m would result from setting it equal to 1/2*mv^2, now v = sqr(GM/r), and the orbit needs to be less than this. interesting stuff...
Sorry, escape velocity is going a bit too far, literally and figuratively. You do not need to be at escape velocity to remain in orbit, because that is partly what escape velocities are, the object will be able to escape from the gravitaional influnce of the moon.
Try in an orbit, we assume it is in circular motion. Think of what equations you need to apply.
Related Threads on Help acceleration
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
