Homework Help: Help Force/Tension Problem
  1. Sep 19, 2007 #1
    Help!!! Force/Tension Problem
    A 2.4 kg ball tied to a string fixed to the ceiling is pulled to one side by a force F to an angle of 32.1° from the ceiling.
    (a) Just before the ball is released and allowed to swing back and forth, how large is the force F that is holding the ball in position?
    (b) Just before the ball is released and allowed to swing back and forth, what is the tension in the string?
    2. Relevant equations
    3. The attempt at a solution
    Hi all, I am new to physics, and this homework is kicking my butt! haha, so first I tried to convert the 2.4kg to Newtons (9.8N/kg), and then use sin and cos to find the force in the x and y directions. I get 19.9 in the x direction, and 12.5 in the y direction. Our homework is submitted electronically, though, and it doesn't think my answer for a) is right.... I really don't know how to do b) :cry:
    If someone could help me that would very much appreciated, this is due at 7 in the morning!
    Thanks,
    Damian
  3. Sep 19, 2007 #2
    learningphysics
    Did you draw a freebody diagram? What are the forces acting on the ball? What are the forces acting in the y-direction? In the x-direction?
  4. Sep 19, 2007 #3
    I drew a diagram, and I thought I found the forces in the x and y directions (by using sin and cos), but I can't seem to think of anything else. My professor very quickly went over this, and I am really stuck (i have work on it for about a half hour....). Any other suggestions to point me in the right direction?
    Thanks
  5. Sep 19, 2007 #4
    learningphysics
    Can you describe exactly the forces you found and what you did? We will help you along from there...
  6. Sep 19, 2007 #5
    Ok, since you are pulling the ball back, and supporting it in the air, you would have to apply a force "backward" (or in the x direction, as I drew it), and I think there has to be a force in the y direction, since the ball would move up some as you support it. i took the sin of 32.1, and multiplied it by 23.52 (which would be the force on the string, converted from kg, i think.... ;) to find the y force, and i got 12.5. i did the same with the cosine, to find the x force, and i got 19.92.
    I know there are several areas in which i could be wrong. for one, maybe 2.4kg should not be converted to newtons like that.... also, i could be wrong about the force on the hypotenuse, or the string, being 23.52.....
    beyond that, i really dont know what to do :(
    Thanks!
  7. Sep 19, 2007 #6
    learningphysics
    I think the important step where you are going wrong is getting the components of the tension... Suppose the tension is T. Now 32.1 is the angle with the horizontal?
    So what is the vertical component of T... what is the horizontal component of T? just give the answer in terms of T, sin, cos etc.
  8. Sep 19, 2007 #7
    http://img210.imageshack.us/img210/9384/untitledxk6.png [Broken]
    So the tension, T, is what I am trying to find, along with the x and y values? so sin(57.9) would be y/t
    and cos(57.9) would be x/t ?
    do i have it right so far?
  9. Sep 19, 2007 #8
    learningphysics
    Yes, looks good. So what is the horizontal component of T? What is the vertical componen of T?
    Use upwards as positive. Down as negative. Right as positive. Left as negative.
  10. Sep 19, 2007 #9
    so, assuming that my 2.4kg to 23.52N conversion is right, and T is 23.52, y would be +19.9, and x would be -12.50 ?
    edit: oops, i switched x and y on my diagram...
  11. Sep 19, 2007 #10
    learningphysics
    wait... you're jumping too far ahead... you don't know T yet... in terms of T, what is the horizontal component of T and the vertical component of T...
  12. Sep 19, 2007 #11
    so...
    t(y)=y/(sin(57.9))
    and
    t(x)=x/(cos(57.9))
    oh, and i dont think i mentioned it before, but they want the answer in newtons,
    Thanks
  13. Sep 19, 2007 #12
    learningphysics
    If you have a vector with magnitude R, acting at an angle theta from the positive x axis... what is the x-component of this vector?
  14. Sep 19, 2007 #13
    (R)(cos(theta)) ?
  15. Sep 19, 2007 #14
    learningphysics
    exactly. The x component is R cos theta. The y component is Rsin theta.
    Do the same type of thing here... except instead of R we have T...
  16. Sep 19, 2007 #15
    so
    x=T(sin57.9)
    and
    y=T(cos57.9)
  17. Sep 19, 2007 #16
    learningphysics
    exactly.
    Now write the [tex]\Sigma{F} = ma[/tex] in the x-direction. Also write the f=ma equation in the y-direction.
  18. Sep 19, 2007 #17
    im sorry, but i dont think we went over this in class, i cant find reference to it in the book either. could you explain? sorry to be so stupid :(
  19. Sep 19, 2007 #18
    so if force equals mass * acceleration, than the force would be zero, wouldn't it?
  20. Sep 19, 2007 #19
    learningphysics
    No prob. don't feel bad. this stuff takes time to get used to.
    Looking at the diagram... I'm going to assume the F force acts on the ball towards the right... the two forces in the horizontal direction are, F acting to the right, and Tsin57.9 acting to the left.
    So [tex]F - Tsin(57.9) = ma_x[/tex] (where ax is the acceleration horizontally)
    but ax =0, so:
    F - Tsin(57.9) = 0
    Try doing the same type of thing vertically to get another equation.
  21. Sep 19, 2007 #20
    wouldn't it be F-T cos(57.9) = 0 for the vertical direction?
  22. Sep 19, 2007 #21
    learningphysics
    No because F doesn't act vertically... also you need to take gravity into account.
  23. Sep 19, 2007 #22
    would you have T(cos57.9)+23.52, the 23.52 being (2.4)(9.8) to account for gravity?
  24. Sep 19, 2007 #23
    learningphysics
    Yes. But use upwards positive and downwards negative. ie: Tcos(57.9) - 23.52 = 0. Hope the directions make sense.
    From these 2 equations you can solve for F.
  25. Sep 19, 2007 #24
    THANK YOU SO MUCH!!!! YOU ARE GODLY!!!
    thanks so much for all of the help!!
    I got both parts right! WWOOOOOOHOOOO!!
  26. Sep 20, 2007 #25
    learningphysics
    :smile: no prob.
