Homework Help: Help me find the antiderivates
  1. Aug 31, 2014 #1
    RJLiberator
    f(x) = 1/xln(x)
    g(x) = e^x sqrt(1+e^x)
    Hm.
    I guess, my first question is: Do I need to use U substitution?
  3. Aug 31, 2014 #2
    PeroK
    What substitutions are you thinking of using?
  4. Aug 31, 2014 #3
    RJLiberator
    Well, that's where I am kinda stuck.
    Let's take the first one for example.
    If I were to substitute U as ln(x) I would get:
    U = ln(x)
    du = 1/xdx
    Working that out, I get 1/u*du
    I suppose that works. Seems to check out with me.
    Then it becomes ln(u) and the answer becomes ln(ln(x))
    Um, wow. That is the right answer, that was a LOT easier then I made it out on my paper 0_0. It's as if I went on this site and magic happens.
    OKAY, Cool, let's try example two:
    e^x sqrt(1+e^x)
    My two possibilities for U seem to be either e^x or sqrt(1+e^x)
    Lets try U=e^x and du = e^x dx
    Hm, on first impression, this does not make sense, but let's see:
    du sqrt(1+u)
    (2(1+u)^3/2)/3
    Inputing back for e^x
    (2(1+e^x)^3/2)/3
    That seems to be the correct answer...
    Is my reasoning correct?
  5. Aug 31, 2014 #4
    PeroK
    Yes, looks like you got it. Don't forget the constant of integration, though.
    You may want to take a quick look at using Latex to post mathematics. E.g:
    [tex]\int e^x \sqrt{1 + e^x}dx = \int \sqrt{1 + u}du = \frac{2}{3}(1+u)^{\frac{3}{2}} + C[/tex]
    If you "quote" my post, you'll get the Latex I used and see how it's done.
  6. Aug 31, 2014 #5
    RJLiberator
    PeroK, thank you kindly for all of your help here. I will look at using Latex for future posts now that I will likely be posting more here due to semester starting :).
    Kind regards.
  7. Aug 31, 2014 #6
    RJLiberator
    Okay, one more quick question on a different question (I don't feel it is warranted to create a thread):
    True or False?
    For any real numbers a and b:
    [itex]\sqrt{(a+b)^2} = a+b[/itex]
    My problem with this problem is that (a+b)^2 = (a+b)(a+b) = a^2+2ba+b^2 OR does it equal a^2+b^2
    I am leaning towards thinking this statement is TRUE as 3+6 = 9 raised to the second power = 81. Square root of 81 = 9 and 3+6 = 9 on the other side.
    Correct?
  8. Aug 31, 2014 #7
    PeroK
    What about negative numbers?
  9. Aug 31, 2014 #8
    RJLiberator
    Oh, I am sorry Perok - I mean the absolute values of a and b on the right side, let me rewrite.
    True or False?
    [itex]\sqrt{(a+b)^2} = |a|+|b|[/itex]
  10. Aug 31, 2014 #9
    Try some examples. Try various combinations of positive and negative numbers. For example, ##a## positive and ##b## positive, ##a## negative and ##b## positive, etc.
  11. Aug 31, 2014 #10
    PeroK
    No. For example, a = 1, b = -1.
    Taking the square root of a square quite often seems to cause trouble. Note that:
    [tex]If \ x \ge 0, \ \ then \ \ \sqrt{x^2} = x; \ \ and \ if \ x < 0, \ then \ \sqrt{x^2} = -x[/tex]
    So, now you can apply this to (a + b).
  12. Aug 31, 2014 #11
    RJLiberator
    I have tried many examples now, and they all check out, so it must be true.
    AH.
    I get it now. (a+b)(a+b) = (a+b)^2
    (a+b)^2 = a^2+b^2+2ab
    Ah... silly me... thanks.
    Aha.
  13. Aug 31, 2014 #12
    Ray Vickson
    Have you tried a = 1 and b = -2?
Have something to add?
Draft saved Draft deleted
