1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Help me in finding the limit
  1. Jun 21, 2007 #1
    can you please help me to find the limit ?
    limit n->infinity ((-1)^(n-1))/n ?
    i tried to find the limit using the limit at infinity trick,...i got the value as 0
    but the solution given are not matched.
    can you please help me out ?
    Thanks
    Mc
  3. Jun 21, 2007 #2
    limit doesn't exist
  4. Jun 21, 2007 #3
    Dick
    The limit is zero. If the question is misstated and meant to be a series sum then its not.
  5. Jun 22, 2007 #4
    limit oscillates? limits that oscillate don't exist?
  6. Jun 22, 2007 #5
    VietDao29
    What do you mean by "Limit oscillate"? The limit is 0, it does not oscillate. However, the value for the expression does oscillate, but, in the end, they all converge to 0 so the limit does exist, and it's 0. It's like the limit:
    [tex]\lim_{n \rightarrow \infty} \frac{\sin n}{n} = 0[/tex]
    The value for the expression oscillate around 0, but as n tends to infinity, they converge to 0, so the limit is 0.
    Not to be confused with, [tex]\lim_{n \rightarrow \infty} (-1) ^ n[/tex]. This limit does not exist, since, when n is odd, the value for the expression is -1, and when it's even, it's 1. They don't converge, so there's no limit there.
    @macjack: Are you familiar with the Squeeze Theorem?
  7. Jun 22, 2007 #6
    Thanks
    Thanks for your response.
    The answers given are
    a) The sequence approaches the limit from RHS
    b) The sequence approaches the limit from LHS
    c) The sequence oscillates about the limit
    d) none of the above.
    None of my answers and few of them answers also didnt match this
    choose.
    and in the answer section he didnt mention anything about which one is the correct one...it just says...sequence:1, -1/2, 1/3......
    what does it mean ?? is that question wrongly stated ?? i have this doubt because he is start using 1,2,3...for 'n' right ??
    any clue ??
    I don't know about the squeeze theorem !! Let me check out that today.
    Thanks
  8. Jun 22, 2007 #7
    dude... you have to tell people it's a sequence. in which case the correct answer is c
  9. Jun 22, 2007 #8
    thanks ice109
    thanks ...
    i am a newbie into calculus..didnt face the limits of sequences till now.
    anyway thanks for your help.
  10. Jun 22, 2007 #9
    now someone help me, why is the limit of the expression 0 and not nonexistant
  11. Jun 22, 2007 #10
    Dick
    Because the difference between zero and (-1)^(n-1)/n approaches zero as n approaches infinity. The sense of the multiple choices is simply how does it approach it. But approach it, it certainly does. 1/n goes to zero and the sign oscillation doesn't change that.
  12. Jun 22, 2007 #11
    why i said it is 0 is ?
    there is a common trick when you take lim x->infinity, based on the powers of the numerator and denominator in a polynomial equation.
    1) if the orders are same , then just take the coefficients of higher order terms and divide it.
    2) if the order of denominator is bigger than the top, then its limit is 0.
    3) if the order of the denominator is lesser than the top, then the limit is infinity
    or no limit (i have a doubt here)...am i correct with this condition..
    so for this problem, we satified second condition..so i said it is 0...
  13. Jun 22, 2007 #12
    Dick
    It is zero. Are you doubting it?
  14. Jun 23, 2007 #13
    VietDao29
    Yes, you can do it this way. When n tends to infinity, the denominator also grows without bound, so +1, or -1, when divided by that denominator will tend to 0. So, the limit is 0.
  15. Jun 23, 2007 #14
    what about the third statement ?
    >3) if the order of the denominator is lesser than the top, then the limit is >infinity or no limit (i have a doubt here)...am i correct with this condition..
    Did anyone know what is the correct answer for this ??
  16. Jun 23, 2007 #15
    CompuChip
    As Dick already said, the limit can be defined as follows: a sequence [tex](x_n)_{n \in \mathbb{N}}[/tex] has a limit x, if we can make the difference between xn and x as small as we want by choosing n appropriate.
    For example, we see that [tex]x_n = 1/n[/tex] has limit zero, because if I give you some number [tex]\epsilon > 0[/tex] you can always give me an n for which [tex]1/n < \epsilon[/tex]. On the other hand, [tex]x_n = \frac{n}{2}[/tex] does not have a limit. For example, if you claim it's "infinity", I can ask you for a number n such that [tex]|\frac{n}{2} - \infty| < \epsilon[/tex] and you will be unable to give it to me, however big my epsilon is, since the distance is always infinity. In this case, we say the limit does not exist, although to indicate this we usually (technically speaking, quite sloppily) write
    [tex]\lim_{n \to \infty} \frac{n}{2} = \infty[/tex].
    Now maybe it's a nice exercise for you to try and prove that way the limit (or its non-existence) of
    [tex]\frac{x^n}{x^m}[/tex]
    for the cases n < m, n = m and n > m.
  17. Jun 23, 2007 #16
    HallsofIvy
    Staff Emeritus
    IF the sequence {an} converges to a non-zero number, then the sequence {(-1)nan} does not converge since, if we assume a limit of a, some terms of the sequence, for arbitrarily large n, will be at least |a| (distance from a to 0) away. If, however, {an} converges to 0, {(-1)nan} also converges to 0.
Similar Discussions: Help me in finding the limit
  1. Help me find a limit! (Replies: 4)
Loading...
