Understanding Time Dilation: The Paradox of Aging in Outer Space
  • Thread starter fluidistic
  • Tags
    Paradox
In summary, the conversation discusses the concept of time dilation in special relativity and its implications for aging. The observer on Earth ages at a slower rate than the observer in outer space, leading to a potential paradox when considering the age of the Sun. However, the two effects are unrelated and the paradox is resolved.
fluidistic
261
I've thought about something that is a paradox to me. I think I know what would happen in reality but I can't explain why the other option is discarded.
Imagine you are an observer that can live "forever". You are over the Earth and looking toward the Sun. For the sake of simplicity, let's assume the Earth doesn't rotate on itself, but only moves in orbit around the Sun.
I've calculated (with special relativity only) that if the observer was to leave the Earth and wait for it to come back 1 year later, this observer would age 0.2 s more than someone that stayed on the Earth for 1 year. I assumed 1 year=365 days, the speed of the Earth with respect to the observer: 30 km/s. Since this outer space observer isn't moving with respect to the Sun, it also means (neglecting general relativity) that you will see the Sun aging 0.2 s less than you (you are still over the Earth), after 1 year.
After 1000 years this makes 200 s, etc.
So when you look at the Sun and it has been existing since say around 4.5 billions years ago (assume Earth too is this old); is the Sun older than 8 minutes, say several years old?
I say 8 minutes because it's approximately the time that photons leaving out Sun's surface take to reach the Earth.
I know that the answer is indeed around 8 minutes, but because of special relativity, I'm totally confused.
Equation: [itex]\Delta t = \gamma \Delta t '[/itex].
I'm not sure I understand your question. The fact that it takes light 8 minutes to reach the Earth from the Sun has nothing to do with how much older or younger the Sun might be than the Earth, due to their relative motion. By your calculation, taking only SR into account, the observer on the Sun would have aged by an additional 1 billion seconds or so (which is about 30 years) compared to an observer on the Earth, over the 4.5 billion years since the solar system was formed. The 8 minutes just means that, if the two observers were exchanging radio messages, say, updating each other on how much they have aged, each one, at any given time, would be receiving a message that was sent 8 minutes earlier by the other.
Does this help any?
If the observer is not moving with respect to the sun then there will be no time dilation between them. (Ignoring gravitational time dilation.)
As for the rest of your question, I am not too sure what you are asking, sorry.
The sun and the space observer will age at the same rate. The Earth bound observer (and the earth) will age 0.2 seconds less per year than the sun. So that means that the Earth and the Earth bound observer, if he's been there since the beginning, will be about 29 years younger than the sun. However, when looking at the sun from earth, you will see it as it appeared 8 minutes earlier (according to the rest frame of the sun).
Ah thank you all guys. Now I think I understand...
Basically the Sun would age more (I correct because in my OP I stated less) than an observer on the Earth as you said guys.
Yes this helps a lot (what you all told me).
Thanks a lot. I realize these are 2 totally different "effects".
"Paradox taken down".
1. What is a paradox?
A paradox is a statement or situation that seems to contradict itself, but upon closer examination may actually be true.
2. How can a paradox be harmful?
A paradox can be harmful because it can create confusion and uncertainty, making it difficult to make decisions or take action.
3. Why do we need to "kill" a paradox?
To "kill" a paradox means to resolve it or find a solution that eliminates the contradiction. This is important in order to maintain logical consistency and avoid confusion.
4. What are some common types of paradoxes?
Some common types of paradoxes include self-referential paradoxes, such as the liar paradox, where a statement contradicts itself; logical paradoxes, where a statement leads to a logical contradiction; and probabilistic paradoxes, where the expected outcome is different from the actual outcome.
5. How can we resolve a paradox?
There are various ways to resolve a paradox, including changing the assumptions or definitions involved, finding a new perspective or context, or finding a logical loophole that resolves the contradiction. In some cases, a paradox may also be accepted as true through the use of dialectics or paradoxical thinking.
