What Is Ferrofluid and How Does It Create Unique Optical Effects?
  • Thread starter Mk
In summary: Ferrofluid is a superparamagnetic liquid composed of surfactant-encapsulated, nanoscale sub-domain magnetic particles suspended in a carrier fluid with a high magnetic permeability and very low magnetic hysteresis. In this photograph, approximately five milliliters of ferrofluid was poured into a petri dish and two N42 grade neodymium iron boron (Nd2Fe14B) rare-earth magnets were strategically placed under a commercially printed watercolor painting of breaking waves. The interaction of the magnets' fields, the surface tension of the ferrofluid, and the Earth's gravitational field resulted in stable three-dimensional liquid spikes. Interesting optical effects are exhibited from the
Mk
2,043
This is describing a photograph I took, and I am not sure of the proper grammar to use at times. Should I put commas in the first sentence? Butcher it; why don'tcha? I want to make it best possible.
approximately five milliliters of ferrofluid was poured into a petri dish, and two N42
Earth's gravitational field result in stable three-dimensional liquid spikes. Interesting optical effects are exhibited from the transparency, color (both as a function of depth), and curvatures of the ferrofluid, as well as the several different wavelengths of light projected onto specific regions of the photograph.
Ferrofluids are superparamagnetic liquids composed of magnetic particles suspended in a carrier fluid; therefore, ferrofluids have a high magnetic permeability and very low magnetic hysteresis.
Why are you being so damn verbose?
Not that it's a rule that many pay attention to anymore, or that anyone would notice, but the whole comprises the parts and the parts compose the whole.
"Ferrofluid is a superparamagnetic liquid that comprises surfactant-encapsulated..."
What Mk has seems to agree with that. 'X composes Y' iff 'Y is composed of X'. The former is in the so-called active voice; the latter is in the passive voice.
When should I prefer to use the active/passive voice?
Here the use of passive voice is preferred.
:tongue2:
I'm not really familair with the concepts people have introduced about this. But take a look at what placing an expression at the beginning of a sentence does.
(1) Rachel ate asparagus for an experiment.
(2) a. Asparagus, Rachel ate for an experiment.
(2) b. Asparagus was eaten by Rachel for an experiment.
(3) For an experiment, Rachel ate asparagus.
If it seems like (1) is about Rachel, (2a-b) are about asparagus, and (3) is about an experiment, great, that's what I was aiming for. As a rule of thumb, in English, to make a sentence S be about X, put X at the beginning of S, and to make S not be about X, don't put X at the beginning of S. I can't really say more. If you are dying for more, maybe this will help, or you can google 'topic' or 'topicalization'.
Ferrofluid is a superparamagnetic liquid. It is composed of surfactant-encapsulated, nanoscale, sub-domain magnetic particles. These are suspended in a carrier fluid with a high magnetic permeability and a very low magnetic hysteresis. In the experimental results shown in Fig.?,
approximately five millilitres of ferrofluid were poured into a petri dish. Next, two N42 grade neodymium iron boron (Nd2Fe14B) rare-earth magnets were placed under a print showing breaking waves. <Need to say why this print is used>The
interaction of the magnetic fields, together with the surface tension of the ferrofluid and the Earth's gravitational field are shown to result in stable three-dimensional liquid spikes. Moreover, interesting optical effects are observed. Namely, color, as a function of depth, and curvatures of the ferrofluid. Note that, the several different wavelengths of light projected onto specific regions of the photograph are also shown.
edit: btw, it's grammar!
1. What is the correct spelling of "grammar"?
The correct spelling of "grammar" is with two "m"s, not one. It is a common mistake to misspell this word.
2. How can I improve my grammar skills?
Improving grammar skills takes practice and patience. One way to improve is by reading and writing frequently, as this will expose you to proper grammar usage. You can also take online courses or work with a tutor to learn more about grammar rules and practice exercises.
3. Why is proper grammar important?
Proper grammar is important because it helps to effectively communicate ideas, thoughts, and messages. It also shows professionalism and attention to detail, both of which are important in various fields and industries.
4. What are some common grammar mistakes to avoid?
Some common grammar mistakes to avoid include subject-verb agreement errors, using the wrong verb tense, confusing homophones (words that sound the same but have different meanings), and incorrect punctuation usage.
5. Can I use online tools to check my grammar?
Yes, there are many online tools available to check grammar and spelling. However, it is important to still double-check the suggestions made by these tools, as they can sometimes miss errors or make incorrect corrections.
