Help me with unit vectors, please!
  • Thread starter mubeen916
mubeen916
Here's the problem I've been having difficulty with:
Find a vector with a magnitude of 1.00 that bisects the angle between the vectors 5.00i + 11.0j and 2.00i − 1.00j. Give your answer in rectangular coordinates.
Someone else had posted this same question before, but the answer that was given was incorrect.( (0.94 i + 0.34 j))
Please help by explaining the solution and how you arrived at it. I appreciate the help!
Answers and Replies
gneill
Mentor
20,945
2,886
Uh-Uh. You have to show what you've tried first.
mubeen916
Okay, so I got the sum of both of the vectors to be (7.00i, 10.00j). I took the square root of 7^2+ 10^2, which = 12.2
Now, to get the resulting vector, I used (7.00/12.2i, 10.0/12.2j) to get (.57i, .82j). Where did I go wrong?
gneill
Mentor
20,945
2,886
But you're not looking for the resultant of adding the vectors; You're looking for a vector that is (in terms of angle) halfway between them. Drawing a diagram with labeled angles might help.
mubeen916
Actually, I realized I had to find the corresponding unit vectors given for the vectors originally stated in the problem.
To find the unit vectors, I took the first vector (5.00i, 11.0j) and did the following:
5/ square root of 5^2+11^2i, and 11/square root of 5^2 +11^2j, which gave me the unit vector (.414j, .906j).
I did the same for the second vector (2.00i-1.00j).
2.00/square root of 2^2+-1^2i, -1/square root of 2^2+ -1^2j, which gave me the unit vector (.89i, -.447j).
Then I repeated the steps that I wrote out in my previous post using the unit vectors.
.414 + .89/ square root of (.414+.84)^2 +(.906-.447)^2 i, .906+.89/ square root of (.414+.84)^2 +(.906-.447)^2 j
which gave me the final unit vector of (.94i 1.30j). Apparently this is incorrect but I don't understand what I did wrong.
gneill
Mentor
20,945
2,886
Okay, it just 'clicked' as to how your approach to the problem will work. The resultant of two unit vectors will indeed bisect them. That's fine! The difficulty must be with the implementation (i.e. finger problems with the math!).
The value you get for the x-component for the resultant looks okay. Take a closer look at the y-component. In fact, check carefully where the two values you're using in the numerator are coming from...
mubeen916
I'm stumped. Physics is not my thing- the answer is probably obvious, but the lightbulb hasn't gone off in my head!
Suggested for: Help me with unit vectors, please!
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
