Help needed Before 0930 hrs Fiji Time Please
  1. Oct 2, 2011 #1
    Help needed...Before 0930 hrs Fiji Time....Please
    Write a program using C++ as the programming language to implement the various line encoding scheme as listed in Table 4.1, pages 114-115, Forouzan except the multilevel schemes 2B1Q, 8B6T and 4D-PAM5. So there will 6 line coding schemes altogether that needs to be implemented.
    1. Your program requests users to enter 8-bit word (digital data) to encode (convert) and then come up with the corresponding digital signal.
    2. The 8-bit word should be in Hexadecimal format. This Hexadecimal word should then be converted to bits before applying a line encoding scheme.
    3. Your program should allow the user to select a line coding scheme to use.
    4. Based on the line coding scheme in #3, your program should then write to the screen as output either +1 for a positive, 0 for zero, and -1 for a negative voltage digital signals. To make your output readable separate these with appropriate spaces.
    5. Program be repeated for a new 8-bit word.
    Your program should show:
    1. Proper coding practices/principles as you have learned in CS111 and CS112.
    a. Proper layout/structure
    b. Proper use of comments
    c. Proper use of functions (may use)
    2. Validate all input, in this case the Hexadecimals to represent the 8-bit word.
    3. For each line coding, you must ask user to state assumptions such as the last signal has a positive voltage, negative voltage, or zero voltage. Program output should consider each assumption.
    4. Run a number of Test Cases and take a snapshot of the corresponding output such as applying all implemented line codings to a single input word.
    5. You may add details as you would prefer.
    6. The instructions here are very general, so you are free to deicide to what extend in term of details you can implement each line encoding scheme.
    2. The attempt at a solution
    Code (Text):
    #include <iostream>
    #include <stdlib.h>
    #include <string>
    #include <ctype.h>
    using namespace std;
    void Binary_print(int [], int);
    void NRZ(int []);
    void NRZL(int []);
    void NRZI_pos(int []);
    void RZ(int []);
    void AMI_pos(int []);
    void AMI_neg(int []);
    const int maxibit = 4;//number of bits per hexadecimal figure
    int main()
        char input[2];//hexadecimal input
        int x1[maxibit];// 4-bit binary conversion for first hexadecimal input
        int x2[maxibit];// 4-bit binary conversion for second hexadecimal input
        int array1, array2;
        bool bool_arrayA,bool_arrayB;
        cout << "Enter a 8-bit word (in Hexadecimal): ";
        cin >> input[0] >> input[1];
        cout << endl;
            if (!(input[0] == 'a' || input[0] == 'A' || input[0] == 'b' || input[0] == 'B' || input[0] == 'c' || input[0] == 'C' || //validating first array element
                  input[0] == 'd' || input[0] == 'D' || input[0] == 'e' || input[0] == 'E' || input[0] == 'f' || input[0] == 'F' ||
                  input[0] == '0' || input[0] == '1' || input[0] == '2' || input[0] == '3' || input[0] == '4' || input[0] == '5' ||
                  input[0] == '6' || input[0] == '7' || input[0] == '8' || input[0] == '9')||
                !(input[1] == 'a' || input[1] == 'A' || input[1] == 'b' || input[1] == 'B' || input[1] == 'c' || input[1] == 'C' || //validating second array element
                  input[1] == 'd' || input[1] == 'D' || input[1] == 'e' || input[1] == 'E' || input[1] == 'f' || input[1] == 'F' ||
                  input[1] == '0' || input[1] == '1' || input[1] == '2' || input[1] == '3' || input[1] == '4' || input[1] == '5' ||
                  input[1] == '6' || input[1] == '7' || input[1] == '8' || input[1] == '9'))
                cout << "Invalid Input!\n\n";
           else
               cout << "Hexadecimal input: " << input[0] << input[1] << endl << endl;
               cout << "Binary conversion: ";
               switch (input[0]) // assigning integer value to first character element and printing it's binary value
                 case '0': array1 = 0;
                      Binary_print(x1, array1);
                      break;
                 case '1': array1 = 1;
                      break;
                 case '2': array1 = 2;
                      break;
                 case '3': array1 = 3;
                      break;
                 case '4': array1 = 4;
                      break;
                 case '5': array1 = 5;
                      break;
                 case '6': array1 = 6;
                      break;
                 case '7': array1 = 7;
                      break;
                 case '8': array1 = 8;
                      break;
                 case '9': array1 = 9;
                      break;
                 case 'a': array1 = 10;
                      break;
                 case 'A': array1 = 10;
                      break;
                 case 'b': array1 = 11;
                      break;
                 case 'B': array1 = 11;
                      break;
                 case 'c': array1 = 12;
                      break;
                 case 'C': array1 = 12;
                      break;
                 case 'd': array1 = 13;
                      break;
                 case 'D': array1 = 13;
                      break;
                 case 'e': array1 = 14;
                      break;
                 case 'E': array1 = 14;
                      break;
                 case 'f': array1 = 15;
                      break;
                 case 'F': array1 = 15;
                      break;
                 default:
               switch (input[1]) // assigning integer value to second character element and printing it's binary value
                 case '0': array2 = 0;
                      Binary_print(x2, array2);
                      break;
                 case '1': array2 = 1;
                      break;
                 case '2': array2 = 2;
                      break;
                 case '3': array2 = 3;
                      break;
                 case '4': array2 = 4;
                      break;
                 case '5': array2 = 5;
                      break;
                 case '6': array2 = 6;
                      break;
                 case '7': array2 = 7;
                      break;
                 case '8': array2 = 8;
                      break;
                 case '9': array2 = 9;
                      break;
                 case 'a': array2 = 10;
                      break;
                 case 'A': array2 = 10;
                      break;
                 case 'b': array2 = 11;
                      break;
                 case 'B': array2 = 11;
                      break;
                 case 'c': array2 = 12;
                      break;
                 case 'C': array2 = 12;
                      break;
                 case 'd': array2 = 13;
                      break;
                 case 'D': array2 = 13;
                      break;
                 case 'e': array2 = 14;
                      break;
                 case 'E': array2 = 14;
                      break;
                 case 'f': array2 = 15;
                      break;
                 case 'F': array2 = 15;
                      break;
                 default:
             cout << endl << endl;
             cout << "Select a line encoding scheme with its assumption from the menu below:\n\n";//displaying menu for the line coding schemes to choose from
             cout << " UNIPOLAR:\n\n";
             cout << " \t1. NRZ\n\n";
             cout << " POLAR:\n\n";
             cout << " \t2. NRZ-L\n\n";
             cout << " \t3. NRZ-I                   (Assuming previous signal is postive)\n\n";
             cout << " \t4. NRZ-I                   (Assuming prevoius signal is negative)\n\n";
             cout << " \t5. RZ\n\n";
             cout << " \t6. Manchester\n\n";
             cout << " \t7. Differential Manchester (Assuming previous signal is postive)\n\n";
             cout << " \t8. Differential Manchester (Assuming prevoius signal is negative)\n\n";
             cout << " BIPOLAR:\n\n";
             cout << " \t9. AMI                     (Assuming previous signal is postive)\n\n";
             cout << " \t10. AMI                    (Assuming prevoius signal is negative)\n\n";
             cout << " \t11. Pseudoternary\n\n";
             cout << " MULTITRANSITION:\n\n";
             cout << " \t12. MLT-3                  (Assuming previous signal is postive)\n\n";
             cout << " \t13. MLT-3                  (Assuming prevoius signal is negative)\n\n";
             cout << " \t14. MLT-3                  (Assuming prevoius signal is a zero)\n\n";
             cout << "Choose a number from the menu: ";
             string scheme_choice;
             cin >> scheme_choice;
             cout << endl;
             while (!(scheme_choice == "1" || scheme_choice == "2" || scheme_choice == "3" ||
                      scheme_choice == "5" || scheme_choice == "9" || scheme_choice == "10"))//validating input of number choice
                   cout << "Invalid entry! Enter Number again: ";
                   cout << endl;
             if (scheme_choice == "1")
                  NRZ(x1);
                  NRZ(x2);
             else if (scheme_choice == "2")
                  NRZL(x1);
                  NRZL(x2);
             else if (scheme_choice == "3")
                  NRZI_pos(x1);
                  NRZI_pos(x2);
             else if (scheme_choice == "5")
                  RZ(x1);
                  RZ(x2);
             else if (scheme_choice == "9")
                  AMI_pos(x1);
                  AMI_pos(x2);
             else if (scheme_choice == "10")
                  AMI_neg(x1);
                  AMI_neg(x2);
             else
        }//ending brace for first if-else statement
        system("PAUSE");
        return 0;
    void Binary_print(int array[], int num)
         for (int i = 0; i < maxibit; i++)
             array[i] = num % 2;
             num = num/2;
         for (int i = 3; i >= 0; i--)
             cout << array[i];
    void NRZ(int array[])
         for (int i = (maxibit-1); i >= 0; i--)
             if (array[i] == 0)
                 cout << " 0 ";
             else
                 cout << " +1 ";
    void NRZL(int array[])
             if (array[i] == 0)
                 cout << " +1 ";
             else
                 cout << " -1 ";
    void RZ(int array[])
             if (array[i] == 0)
                 cout << "  -1 0  ";
             else
                 cout << "  +1 0  ";
    void AMI_pos (int array[])
         string prev1 = "+1"; //assuming that previous 1 bit produces positive voltage
             if (array[i] == 0)
                cout << " 0 ";
             else
                 if (array[i] == 1 && prev1 == "+1")
                    cout << " -1 ";
                    prev1 = "-1";
                 else
                     cout << "+1";
                     prev1 = "+1";
    void AMI_neg (int array[])
         string prev1 = "-1"; //assuming that previous 1 bit produces negative voltage
             if (array[i] == 0)
                cout << " 0 ";
             else
                    cout << " -1 ";
                    prev1 = "-1";
                 else
                     cout << "+1";
                     prev1 = "+1";
    void NRZI_pos(int array[])
         int lastbit = 0;
         string bit1 = "+1"; //previous change caused by 1 voltage
         //testing these 8 cominations in the format (lastbit  array[i]  bit1): 00+1    00-1     01-1     01+1    11-1    11+1   10+1     10-1
             if (lastbit == 0 && array[i] == 0 && bit1 == "+1") // the previous bit was a 0 which is positive so current bit 0 will be positive
                cout << " +1 ";
                lastbit = 0;
                bit1 = "+1";
             else if (lastbit == 0 && array[i] == 0 && bit1 == "-1") // the previous bit was a 0 which is negative so current bit 0 will be negative
                cout << " -1 ";
                lastbit = 0;
                bit1 = "-1";
             else if (lastbit == 0 && array[i] == 1 && bit1 == "-1")
                cout << " +1 ";
                lastbit = 1;
                bit1 = "+1";
             else if (lastbit == 0 && array[i] == 1 && bit1 == "+1")
                cout << " -1 ";
                lastbit = 1;
                bit1 = "-1";
             else if (lastbit == 1 && array[i] == 1 && bit1 == "-1")// the previous bit was a 1 which is negative so current bit 1 will be positive
                cout << " +1 ";
                lastbit = 1;
                bit1 = "+1";
             else if (lastbit == 1 && array[i] == 1 && bit1 == "+1")
                cout << " -1 ";
                lastbit = 1;
                bit1 = "-1";
             else if (lastbit == 1 && array[i] == 0 && bit1 == "+1")
                cout << " +1 ";
                lastbit = 0;
                bit1 = "+1";
             else//(lastbit == 1 && array[i] == 0 && bit1 = "-1")
                cout << " -1 ";
                lastbit = 0;
                bit1 = "-1";
