How to Find Surface Area of a Circle with Removed Sector | Step-by-Step Guide
  • Thread starter mitz_fitz
In summary, one way to find the surface area of a circle after a sector has been removed is to calculate 9/10 of the full circle's area using the radius and subtract that from the full circle's area. The specific values for this problem are a radius of 750mm and an arc of 36 degrees. Contacting Reuben directly at mitz_fitz@hotmail.com would be appreciated for further assistance.
mitz_fitz
if some people could please allow me to bounce answers off them and show them my work by means of e-mail before I send it away to be marked, it would be highly appreciated, thanks
one problem I have at the moment is I need to find the surface area of a circle after a sector has been removed
the circle has a radius of 750mm and the segment is 36 degrees wide at the edge of the circle
thanks,
reuben
contact me directly mitz_fitz@hotmail.com
Mathematics news on Phys.org
Removing a sector of a circle with an arc of 36 degrees gives 9/10 the area of the full circle. 36 degrees is (360-36)/360 = 324/360 = 9/10. Thus the net area is
[tex] \pi r^2 - \frac{\pi}{10} r^2 [/tex] with r = 750mm.
Hi Reuben,
Thank you for reaching out for help with finding the surface area of a circle with a removed sector. I would be happy to assist you and review your work before you submit it for marking. Let's go through the steps together to make sure you understand the process.
Step 1: Understand the Formula
The formula for finding the surface area of a circle is A = πr^2, where A is the surface area and r is the radius of the circle. However, since we have a removed sector, we need to modify the formula to account for the missing portion of the circle.
Step 2: Find the Area of the Full Circle
First, we need to find the area of the full circle using the given radius of 750mm. Plugging this value into the formula, we get A = π(750)^2 = 1,767,145.87 mm^2.
Step 3: Find the Area of the Removed Sector
Next, we need to find the area of the removed sector. To do this, we need to find the central angle of the sector using the given angle of 36 degrees. Since we know that the circumference of a circle is 360 degrees, we can set up a proportion to find the central angle as follows:
36/360 = x/2πr
Solving for x, we get x = (36/360)(2π)(750) = 47.12 mm.
Now, we can use the formula for the area of a sector, A = (θ/360)πr^2, where θ is the central angle and r is the radius. Plugging in the values, we get A = (47.12/360)π(750)^2 = 7,725.47 mm^2.
Step 4: Subtract the Area of the Removed Sector
Finally, we can subtract the area of the removed sector from the area of the full circle to get the surface area of the circle with the removed sector. So, the final formula would be A = πr^2 - (θ/360)πr^2. Plugging in the values, we get A = 1,767,145.87 - 7,725.47 = 1,759,420.40 mm^2.
Step 5: Double Check Your Work
It is always a good idea to double check your work to ensure accuracy
What is the purpose of the "Help Needed, please view" message?
The purpose of the "Help Needed, please view" message is to request assistance from others who may have more knowledge or expertise in a particular subject or situation.
How can I view the "Help Needed" message?
The "Help Needed" message can be viewed by clicking on the link or opening the message in the designated platform or communication channel.
What should I do if I receive a "Help Needed" message?
If you receive a "Help Needed" message, you can choose to view it and provide assistance if you are able, or you can ignore it if you do not have the necessary knowledge or resources to help.
Why is it important to help others when they ask for it?
Helping others when they ask for it is important because it promotes collaboration and knowledge sharing, which can lead to new discoveries and advancements in various fields of study. It also creates a sense of community and support among scientists.
Is it okay to ask for help as a scientist?
Yes, it is completely okay to ask for help as a scientist. Science is a collaborative field and no one person has all the answers. Asking for help can lead to new perspectives and solutions, ultimately benefiting the scientific community as a whole.
10K
  • Other Physics Topics
