Help on Infrared transmitter Circuit
  1. Jan 18, 2008 #1
    Hi all,
    i need some help on this circuit that im building. i want to get the maximum current for my infrared emitting diode (Kingbright L-53F3C)
    datasheet->http://www.soselectronic.com/a_info/resource/pdf/king/L-53F3C.pdf"
    the peak forward current permitted is 1.2A (condition: 1/10 DutyCycle, and 0,1ms pulse width. but i dont understand how to apply this..
    (the idea is more current equals more distance...)
    i have attached my IR transmitter block diagram...
    i am also using a N-MOSFET BS170 and the maximum current allowed is 500mA continuous and 1200mA pulsed (not really sure what that means either).
    datasheet->http://w3.id.tue.nl/fileadmin/id/objects/E-Atelier/doc/Datasheets/Transistoren/BS170.pdf" [Broken]
    so basically i would help on how do obtain the value of the Resistor R for my signal do be sent more efficiently for my specified frequency (90kHz) and dutycycle (5%) (without burning the IR LED).
    any help is much appreciated thanks
  3. Jan 19, 2008 #2
    dlgoff
    Wouldn't you find the resistance that gives 1.2A current continious, then make sure that your pulses are 10 mircosec or less with a 10% maximum duty cycle?
  4. Jan 19, 2008 #3
    i have calculated the mean current for the IR LED for my signal
    DATA:
    frequency = 90kHz
    Period = 11.11us
    Ton = 0.55us
    Toff = 10.056us
    Dutycycle = 5%
    Ipk = 1.2A (peak current)
    Im= Ipk * 0.05 <=> Im = 60mA (mean current)
    now i must calculate the R to limit the current on the diode
    R = (Vcc - V_led - Vmosfet ) / Im <=> R = (5-1.2-2.1) / 60mA = 28.3 Ohm
    R gives me 28.3 Ohm, but im not very sure about this result i might be missing something...
    then there is the power dissipation which is 100mW
    if someone could help me out with these calculations, i have a book on this but its no very helpfull.
    thanks
    dlgoff : do mean like this -> R = (Vcc - V_led - Vmosfet ) / Ipk , then i just pulse the signal normally?
  5. Jan 19, 2008 #4
    dlgoff
    "dlgoff : do mean like this -> R = (Vcc - V_led - Vmosfet ) / Ipk , then i just pulse the signal normally?"
    Well that's how I would do it, but I'm no expert here.
