• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Help on tension/force problem
  • Thread starter shizfest
1. Homework Statement
The drawing below shows an elastic cord attached to two back teeth and stretched across a front tooth. The purpose of this arrangement is to apply a force to the front tooth. (The figure has been simplified by running the cord straight from the front tooth to the back teeth.) If the tension in the cord is 1.6 N, what are the magnitude and direction of the force applied to the front tooth?
3. The Attempt at a Solution
I tried doing 1.6cos33 = magnitude. Apparantly this is wrong. If anyone can give me a hint or push me in the right direction I would be very grateful. Thanks.
djeitnstine
You should account for the tension of both sides of the string since the tension everywhere is the same.
So would I try 2(1.6cos33) = magnitude ?
Thanks again for any help! Not giving up til I found the correct solution!
T=1.6
Θ=33
If the tension in the cord is 1.6N I assume that means on both sides of the tooth.
What I would try is first to draw a force diagram. I did this and then added up all of the forces that made an impact in the Y-direction (up-down). I came up with..
Sum of Y-Forces == -T(cos(Θ))-T(cos(Θ))
Leading me to believe the method may be..
2(-T(cos(Θ))
which would mean you've already got it, I hope so, heh~
Thanks for the input! To me that seems to be the only explainable way to do the problem.
Related Threads for: Help on tension/force problem
  • Posted
12K
18K
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
