Calculating Probability of Excited State of Harmonic Oscillator
  • Thread starter quickclick330
  • Tags
    Exam
In summary, the conversation discusses an ideal harmonic oscillator and its energy levels separated by a constant of 0.05 eV. It is then brought into contact with a large solid and the probability of the single oscillator being in its first excited state at a temperature of 150 K is calculated using the Boltzmann factor. The probability is determined by the energy levels, the Stefan-Boltzmann constant, and the absolute temperature.
quickclick330
83
Harmonic Oscillator
9. An ideal harmonic oscillator has energy levels separated by a constant 0.05 eV. That
is, the difference between the ground state and the first excited state of this oscillator is
an energy of 0.05 eV. This single oscillator is brought into contact with a large solid
composed of an enormous number of oscillators, and characterized by a temperature of
T=150 K. What is the probability that the single oscillator will be found in its first excited
state?
1. 0.021
2. 0.055
3. 0.098
4. 0.144
5. 0.234
6. 1.000
What relationship should I even start with? Thanks for the help!
This is a simple Boltzmann factor problem.
Recall that the probability of an individual energy level is:
exp(-e/(kT))/sum(exp(-ne/(kT))
where
e is the separation between energy levels
k is the Stefan-Boltzmann constant (make sure you get its units right!)
T is the absolute temperature
in this case, we can neglect all terms n > 1 as they decay rapidly to zero. Also, recal that the energy level for the ground state is 0.
That should help you complete the problem.
I would approach this problem by first understanding the concept of thermal equilibrium and the Boltzmann distribution, which describes the probability of a system being in a particular energy state at a given temperature. In this case, the single oscillator is in contact with a large solid at a temperature of 150 K, which means that it will reach thermal equilibrium with the solid and follow the Boltzmann distribution.
Based on this understanding, the probability of the single oscillator being in its first excited state can be calculated using the following formula:
P(E1) = (g1/g0) * e^(-E1/kT)
where P(E1) is the probability of the oscillator being in its first excited state, g1 is the degeneracy (number of energy states) of the first excited state, g0 is the degeneracy of the ground state, E1 is the energy difference between the first excited state and the ground state, k is the Boltzmann constant, and T is the temperature.
In this case, g1 = 1 (since there is only one energy state at the first excited state), g0 = 1 (since there is only one energy state at the ground state), E1 = 0.05 eV, k = 8.617 x 10^-5 eV/K, and T = 150 K.
Plugging these values into the formula, we get:
P(E1) = (1/1) * e^(-0.05/8.617 x 10^-5 * 150)
= 0.021
Therefore, the probability of the single oscillator being in its first excited state is 0.021 or approximately 2.1%.
It is important to note that this calculation assumes that the oscillator is in thermal equilibrium with the solid and follows the Boltzmann distribution. Additionally, this calculation only considers the single oscillator and does not take into account any interactions or effects from the surrounding oscillators in the solid.
What is a harmonic oscillator?
A harmonic oscillator is a physical system that exhibits periodic motion, where the restoring force is proportional to the displacement from an equilibrium position. Examples include a mass attached to a spring and a pendulum.
What is the excited state of a harmonic oscillator?
The excited state of a harmonic oscillator refers to a state in which the system has absorbed energy and is therefore vibrating at a higher frequency or amplitude compared to its ground state.
How is the probability of the excited state of a harmonic oscillator calculated?
The probability of the excited state of a harmonic oscillator can be calculated using the Boltzmann distribution, which relates the energy of a system to its probability of being in a certain state. Specifically, the probability of being in an excited state is proportional to the energy of the state divided by the overall energy of the system.
What factors affect the probability of the excited state of a harmonic oscillator?
The probability of the excited state of a harmonic oscillator is affected by the temperature of the system, the energy levels of the oscillator, and the energy of the ground state. As temperature increases, the probability of being in the excited state also increases. Higher energy levels and lower energy of the ground state also increase the probability of the excited state.
Why is calculating the probability of the excited state of a harmonic oscillator important?
Calculating the probability of the excited state of a harmonic oscillator is important in understanding the behavior and properties of many physical systems, such as molecules and crystals. It also has practical applications in fields such as quantum mechanics and thermodynamics.
