How to Solve the Differential Equation dy/dx= x^2/y?
  • Thread starter bilb27
In summary, the user is asking for help solving a differential equation and is reminded to post their question in the appropriate forum with their attempted solution using the homework template.
bilb27
Anyone help me with this please.
Solve the differential equation
dy/dx= x^2/y
Hi bilb27, welcome to PF. If you click on the Rules tab above, you will find, among other things, this:
Homework Help:
On posting questions: Any and all high school and undergraduate homework assignments or textbook style exercises for which you are seeking assistance are to be posted in the appropriate forum in our Homework & Coursework Questions area--not in blogs, visitor messages, PMs, or the main technical forums. This should be done whether the problem is part of one's assigned coursework or just independent study. The reason for this is that the scientific and mathematical sections of Physics Forums are to be reserved for discussions and not academic assistance. Since graduate level assignments are meant to be more thought provoking (and hence more worthy of discussion), graduate level questions will be allowed in the relevant part of the main section of PF, provided that the graduate student attempts the problem and shows his work.
NOTE: You MUST show that you have attempted to answer your question in order to receive help. You MUST make use of the homework template, which automatically appears when a new topic is created in the homework help forums. Once your question or problem has been responded to, do not go back and delete (or edit) your original post.
http://www.wolframalpha.com/input/?i=dy%2Fdx%3D+x^2%2Fy
1. What is the meaning of dy/dx in the equation "dy/dx = x^2/y"?
The notation dy/dx represents the derivative of the function y with respect to x. It measures the instantaneous rate of change of y with respect to x at a specific point.
2. How do you find the derivative of "x^2/y"?
To find the derivative of x^2/y, we use the quotient rule, which states that the derivative of a quotient is equal to the denominator times the derivative of the numerator minus the numerator times the derivative of the denominator, all divided by the square of the denominator. In this case, the derivative of x^2 is 2x and the derivative of y is 1, so the final answer is (2xy - x^2)/y^2.
3. What is the significance of the equation "dy/dx = x^2/y"?
The equation represents a relationship between the rate of change of y with respect to x and the variables x and y themselves. It can be used to calculate the slope of a tangent line to the graph of the function y = x^2/y at a given point.
4. How can "dy/dx = x^2/y" be applied in real-life situations?
The equation can be applied in various fields of science and engineering, such as physics, economics, and biology. For example, it can be used to determine the rate of change of a physical quantity, such as velocity or acceleration, in a given system.
5. Can "dy/dx = x^2/y" be solved for y?
Yes, it is possible to solve for y by rearranging the equation to y = x^2/(dy/dx). This gives an implicit expression for y in terms of x and the derivative dy/dx. However, in most cases, it is more useful to leave the equation in its original form and use it to calculate the derivative at specific points.
  • Differential Equations
