Help solving an eqn in Matlab
  1. Oct 19, 2009 #1
    I'm working on a project where the following has to be solved on a regular basis, as new column vectors are added to the matrix X.
    a = x' * inv (X * X') * X
    m is the number of examples
    d is the dimensionality of the vector x
    x is d x 1 and norm2(x) <= 1
    X is d x m, consisting of m "x" vectors arranged column-wise (not row-wise as is typically the case)
    a should be m x 1
    I'm wondering is there a faster way to calculate in Matlab, other than a direct implementation of the above. It's not an equation in the usual form Xw = y, so the built-in solver won't work. I'm wondering are there any decompositions that might help, but bear in mind that the equation is solved, then X is changed, then we return to solve the equation once more for a different x.
  3. Oct 19, 2009 #2
    Why don't you write your own Matlab function?
  4. Oct 19, 2009 #3
    The code in my original post is Matlab code which does solve the equation. My question is not particularly Matlab-centric: it's whether the problem can be re-phrased, through some factorisation or decomposition, which would expedite its solution. Particularly, I'm wondering can it be rephrased in such as way that I can employ the heavily optimised solvers one finds in Matlab and various lin alg libraries like BLAS.
  5. Oct 19, 2009 #4
    Ah, I don't know the answer, but you might want to try posting this (or getting it moved) to the computers/math software section where there are lots of matlab/mathematica type questions.
  6. Oct 19, 2009 #5
    why don't you just take the transpose, then everything goes back to normal ?
  7. Oct 20, 2009 #6
    Actually it won't.
    Take a standard linear regression problem
    X * w = y
    m is the number of training samples
    d is the dimensionality of each training sample xm
    X is m x d the datapoints xm arranged row-wise
    y is m x 1
    w is d x 1
    The standard equations are (less regularization) are
    w = inv(X' * X) * X' * y
    w' = y' * X * inv (X' * X)'
    If you say Z = X' (i.e datapoints are arranged column wise, rather than row-wise), you get
    w' = y * Z' * inv (Z * Z')'
    Now consider my example. In my example I'm expression a new datapoint as a linear combination (the vector a) of all previous datapoints. This is different to the standard regression problem. Hence, whereas w above is d x 1, a is m x 1. So, if we have a new datapoint z, and we want to express it as a linear combination of previous datapoints arranged column-wise in Z. We minimise ||a||2 subject to z = Z * a and thereby get
    a = z' * inv (Z * Z') * Z
    My question is is there any way of rephrasing this so the inverse can be avoided, and the problem solved directly.
    The key diffence in the equations for a and w' is the first term, y is m x 1, but z is d x 1
