Homework Help: Help solving Eigenvalue problem
  1. Sep 23, 2008 #1
    solve the eigenvalue problem
    (-∞)x dx' (ψ(x' ) x' )=λψ(x)
    what values of the eigenvalue λ lead to square-integrable eigenfunctions?
    3. The attempt at a solution
    (-∞)xdx' (ψ(x' ) x' )=λψ(x)
    differentiate both sides to get
    ψ(x)x=λ d/dx ψ(x)
    ψ(x)x/λ= d/dx ψ(x)
    2xe x^2 =d/dx e x^2
    so ψ(x) = e x^2 and λ = 2
    but this is not square integrable so either this is incorrect or there are other solutions I am not seeing
    Can anyone help me find what I am missing?
    Thank you
  3. Sep 23, 2008 #2
    Dick
    You want to solve the differential equation, ψ(x)x/λ= d/dx ψ(x) Separate the variables. You should get a solution with a lambda in it. Figure out what values of lambda make it square integrable.
  4. Sep 23, 2008 #3
    Hello,
    I think there are other solutions.
    Take your equation,
    [tex] x\psi\left(x\right) = \lambda\frac{d}{dx}\psi\left(x\right)[/tex]
    and substitute [tex] \psi\left(x\right) = \exp\left(f\left(x\right)\right)[/tex] and see if you don't get an equation for [tex]f\left(x\right)[/tex] which has a solution that depends on [tex]\lambda[/tex].
    Also, don't forget your solution has to be finite at the lower endpoint of the integral ([tex]-\infty[/tex]) in the original problem statement.
  5. Sep 23, 2008 #4
    ok i separated variables, integrated and got
    ψ(x)=e1/(2λ) x2
    however I don't see how this can be square integrable since for any value of λ I can think of the integral of the square will equal infinity. I feel like I am missing something obvious here but I don't know what it is
  6. Sep 23, 2008 #5
    Dick
    Will it equal infinity even if lambda is negative?
  7. Sep 23, 2008 #6
    of course! im so embarrassed, thank you
