Help Solving this PDE
  1. Feb 16, 2016 #1
    Solve y*∂Ψ/∂x-(x/3)∂Ψ/∂y
    2. Relevant equations
    3. The attempt at a solution
    My teacher told me to try separation of variables but and I tried to set Ψ=X(x)Y(y) where X is a function of just X and Y is a function of just y but when I got the solution and put it into the original pde it did not work.
  3. Feb 16, 2016 #2
    Where is the equal sign?
    Can you post your work as well as the answer you got?
  4. Feb 16, 2016 #3
    Sorry the equal sign might help The equation is
    So first I defined Ψ(x,y)=X(x)Y(y)
    thus the equation becomes
    Rearranging and using the multiplication rule
    Rearranging again
    then integrating
    That is as far as I got.
  5. Feb 16, 2016 #4
    Staff Emeritus
    Rearrange the above so one side of the equation only depends on x and the other only on y .
    Then each side must equal a constant, Right?
  6. Feb 17, 2016 #5
    That last step is incorrect- you cannot Integrate that way!
    Instead, at the point where you have yX'/X= (x/3)Y'/Y, divide both sides by xy/3 to get 3X'/(xX)= Y'/(yY).
    The left side depends only on x while the right side depends only on y. But the equation has to be true for all x and y. Imagine changing x while not changing y. Since y does not change the right side does not change. But that means the left side cannot change! That is 3X'/(xX)= C, a constant. Since 3X'/(xX)= Y'/(yY), we also have Y'/yY= C.
    3X'/(xX)= C is the same as 3dX/dx= CxX, a separable differential equation.
    Mod note: Removed some text as being too much help.
Have something to add?
Draft saved Draft deleted
