HELP! Tough Question
  • Thread starter nofear001
Ive been working on this and its a little tough: Whats the answer?
A roof tile falls from rest from the top of a building. An observer inside the building notices that it takes 0.20s for the tile to pass her window whose size is 1.6m. How far above the top of this window is the roof?
(Hint: 2 calculations- Use uniform acceleration equations)
How am i suppose to do this?
a=9.81m/s^2 (im in canada we use 9.81 not 9.8)
t= 0.20s
d= ?
Vi= 0m/s
Vf=?
Thxs
Answers and Replies
chroot
Staff Emeritus
39
Hint: the initial velocity (that is, the velocity as it passes the top edge of the window) is not zero. You need to solve for this velocity, as it will tell you how far from the roof the top of the window is.
- Warren
but the rooftile falls from rest rest= 0m/s
is the answer 2.51 meters?
chroot
Staff Emeritus
39
The roof tile is NOT AT REST when the observer first observes it.
First, it falls from the roof to the top of the window, gaining some velocity. Next, it falls past the window, which the observer times at 0.2 seconds.
Its velocity, when the observer first sees it, is NOT zero. You need to solve for this velocity first. You can then use it to solve for the height of the roof above the window.
- Warren
Heres the caluclations
s = 1.6 t= .2 a = g = 9.81 v =?
s = vt +at^2
and v turns out to be 6.038
well this is the velocity when it reached the point -lets say- x which is when observer first sees it. because it fell off the roof and travelled lets say distance d already...so...
d = (v^.5)/2g
= 1.86 m
i think thats pretty much it.
mukundpa
524
s = (1/2)gt^2
and
s+1.6 =(1/2)g(t+0.20)^2
think!! and eliminate t.
M.P.
Not going to give an answer here but the working I would use seems to differ slightly from others, and arrives at a slightly different expression.
we know that distance = 1/2(inital velocity + final velocity) x time or...
s =1/2(u+v)t
we also know that velocity (v) = u + at
using substitution you can end up with an equation that involves only one variable...that is 'u'
Related Threads on HELP! Tough Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
