Homework Help: Help! Vectors
  1. Mar 26, 2009 #1
    Help! Vectors!!!
    In the triangle ABC, D divides AB in the ratio 3:2, E divides DC in the ratio 1:5 and F divides AC in the ratio 1:2. Show (using position vectors and the section formula) that B, E and F are collinear and find BE:EF
    2. Relevant equations
    Section formula = [tex]\frac{m \textbf{a} = n\textbf{b}}{m+n}[/tex]
    3. The attempt at a solution
    Other than drawing this out, and spotting that they look like they're kind of in a line.
    This isn't due for homework or anything, I'm just revising, so it would be really useful if someone cold explain this to me.
    Any ideas?
  3. Mar 26, 2009 #2
    tiny-tim
    Hi andrew.c! :smile:
    Use the section formula to find the vectors D E and F
    for example, F = … ? :smile:
  4. Mar 26, 2009 #3
    Re: Help! Vectors!!!
    F = [tex]\frac{a+2c}{3}[/tex] ?
  5. Mar 26, 2009 #4
    tiny-tim
    Almost … but it's closer to A,
    so f = (2a + c)/3 :wink:
    Next, what are D and E? :smile:
  6. Mar 26, 2009 #5
    AD/DB = 3/2
    sec. formula...
    [tex]\frac{3a+2b}{5}[/tex]
    DE/EC = 1/5
    sec. formula...
    [tex]\frac{d+5c}{6}[/tex]
    I still dont really understand which value in the ratio is m and which is n, I am just reading it as AD/DB = m/n. Is this right?
  7. Mar 26, 2009 #6
    tiny-tim
    Forget the formula
    I never remember which way round it is …
    I just ask myself each time "which one is it nearer?"
    so if DE:EC = 1:5, then it's nearer D, so … ? :smile:
  8. Mar 26, 2009 #7
    ok, i get that logic :)
    so it would be...
    [tex]D = \frac{2a+3b}{5}[/tex]
    and
    [tex]E = \frac{5d+6}{c}[/tex]
  9. Mar 26, 2009 #8
    tiny-tim
    Yup! :biggrin:
    (except for the obvious mistake … quick! edit it before anyone else notices! :wink:)
    ok, now you have the vectors for B E and F …
    how can you prove they're collinear? :smile:
  10. Mar 30, 2009 #9
    OK, so I have...
    [tex]D = \frac{2a+3b}{5}[/tex] [tex]E=\frac{5d+c}{6}[/tex] and [tex]F = \frac{2a+C}{3}[/tex]
    For collinearity, I need to prove that BE is parallel to EF, with a common point at E?
    I tried this, but not sure if its right - i got the bottom lines to be the same, but my notes indicate that they should be a scalar multiple of each other!
    Sub. D into E to get...
    [tex] E = \frac{2a+3b+c}{6}[/tex]
    [tex]BE = e-b
    =\frac{2a+3b+c}{6} - b
    =\frac{2a+3b+c}{6}-\frac{6b}{6}
    =\frac{2a-3b+c}{6}[/tex]
    [tex]EF = f-e
    =\frac{2a+c}{3}-\frac{2a+3b+c}{6}
    =\frac{4a-2c}{6} -\frac{2a+3b+c}{6}
    Since they are equal, and E was a common point, they are collinear?
    Is BE:EF just 1:1 ?
    Thanks for your help btw!
  11. Mar 30, 2009 #10
    tiny-tim
    Yes, that's very good
    (except you typed a minus for a plus in the last line :rolleyes:)
    the vectors BE and EF are exactly the same, in other words BE = EF, so yes, obviously it's 1:1 :smile:
  12. Mar 30, 2009 #11
    Ta muchly for your help!
    Now i need to tackle vectors intercepting planes. Oh joy of joys!
