Help with a Problem Please (1 Viewer)
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
Help with a Problem Please....
This is the problem.
A projectile is being shot from a cannon and must land in a hole 120 meter aways. What angle must the projectile be shot at to land in the hole? Here are some other numbers
VoX=60cos(??) Voy=60sin(???)
VfX=? Vfy=?
Ax=0 Ay=-9.81 m/s^2
t=?? t=??
dx=120m dy=0
Sorry, just read the post that I need to post homework problems elsewhere.
389
take note that the time for vertical and horizontal motion is the same.
since you know the horrizontal velocity, which is in terms of 60cosZ, can you find time?
Hootenanny
Staff Emeritus
One is also expected to show ones efforts.
I tried finding t this way dx=Vxt === 120m = 60cosZt
t=120/60cosZ
389
yeah you are on the right track, try equate the time into your vertical motion equation.
( they land on the ground the same time, the 2 motions)
The answer would be 0 as far as the vertical aspect is concerned right?? I mean the vertical displacement is 0.
389
correct vertical displacement would be zero
EDITED version
So, would the vertical time be t = sqrt d/VoYt + 1/2a
389
you can simplify the equation into 0 = t(-Voy + 1/2 g t) ( when solving this type of qns remember to state your sign convention, you don't want the case where you get negative time)
so Voy = 1/2 g t
So t=VoY/2g. But how do I find that if I do not know the angle?? You cant divide 60sin of nothing by 2g can you?
389
you can equate the 2 equations u have together, the horizontal and vertical, remember the time is the same for both.
Equate them together? So.... t= (120/60cosZ) * (60sinZ/2g)
389
if you equate in such a way, you have 2 viarables to solve and only one equation to work with.
BTW your equation should be T^2 = ......, since u times the 2 equation together.( but this is not the correct equation to use.)
So that is not the correct way to equate it?? I am really confused here.
389
T = 120/ (60 cos Z)
T = 2(60 sin Z)/(9.81)
120/(60 cos Z) = 2(60 sin Z)/(9.81)
EDIT : i amended the equations. For the time derieved by vertical motion,
Voy = 1/2 g t
(2 voy)/g = t
t = (2 (60) sin Z) / g
You wrote wrongly the equation for your previous post.
Ok. I'm sorry. I thought I put a equals between the two equations. I did not realize it was a muliplication sign. What do I solve for now?? Do I set the equation equal to 0 and divide -120 by 2(9.81)?
389
you can cross mutiply. Then isolate your Z, i used double angle formular for this.
BTW this is the first time i use double angle formular for physic. feels strange
So, 120 m * (2*9.81) = 2354s^2. What would 60 sinZ time 60cosZ be???? 3600 sinZ????
389
this part is wrong, as i have stated about, the equation is
120/(60cos Z) = ((2)(60)sin Z)/ 9.81
thus the correct expression should be 120(9.81) = (2)(60)(60)cos Z sin Z
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
