Help with array
  1. Apr 15, 2010 #1
    What I need help with is the output.
    What should be our output?
    For example, [0, 1) ?
  3. Apr 15, 2010 #2
    Mark44
    Staff: Mentor
    The output should be the 10 elements in the array. Each array element is the number you get from integrating sin(x) on one of the intervals.
    For example, result[0] should have a number that is close to -.5403.
    Edit: that should be .4597.
  4. Apr 15, 2010 #3
    How did you get that number? I thought plain riemann sum (in this case, the right hand rule)
    Here is the short version (with no array), tested [0,1)
    Code (Text):
    #include <iostream>
    #include <cmath>
       using namespace std;
    double integrand(double);
    int main()
        const int SIZE = 10;
        const double WIDTH = 0.0005;  // (b-a)/n
        double sum_array[SIZE];
        double a = 0.0;
        double b = 1.0;
        double sum = 0.00;
        double y1 = 0;
        for (double k = a; k < b; k += WIDTH)
            y1 = integrand(k);
            sum += y1;
        cout << (sum*WIDTH) << endl;
        return 0;
    double integrand(double x)
        double y;
        y = sin(x);
        return y;
    edited the code again (added (sum*WIDTH). I forgot about this)
    I got 0.45968 for [0, 1) using left endpoint
  5. Apr 15, 2010 #4
    Mark44
    Staff: Mentor
    Forgot to add 1. Make that .4597.
  6. Apr 15, 2010 #5
    LOL
    OKay, so it is 1-cos(1) for [0, 1)
    Just really need to confirm that. Otherwise, even if I have perfect codes, with no REAL solution i still cant test it.
    My other classmates are giving me weird numbers.
    Thanks
  7. Apr 15, 2010 #6
    Mark44
    Staff: Mentor
    Your first post says to use the left endpoints.
    Yeah, that's what you should get.
    Some suggestions. Your integrand function can be shortened.
    Code (Text):
        return sin(x);
    Also, you could write a function that does essentially what you do in main. It should take three parameters: left endpoint, right endpoint, number of subintervals, and should return the computed value for that interval. The 10-element array would still be in main -- just loop through each element in the array and call your calculating function for each of the intervals 0 - 1, 1 - 2, ... 9 -10.
