Help with C programming lab
  1. Oct 10, 2009 #1
    Well the program has several functions but I just really need help with reading a text file and splitting the data in the file into a one-dimensional array and a two-dimensional array
    The text file is like this...
    1110 1.5 5.4 6.0 9.8. 8.5 8.3 5.6 9.9
    1112 1.5 5.4 6.0 9.8. 8.5 8.3 5.6 9.9
    I have to somehow get the pin (1110 & 1112) into a 1-d array while putting the rest of the numbers into a 2-d array.
    This is what I have so far.
    /* Reads data of a file and places the first column of info
    into a one dimensional array and the rest into a
    table.
    PRE: table = empty
    ary = empty
    POST:
    int readTable (double scores[][MAX_COLS], double diverId[], int lineSize, char fileName[])
    // Local Declarations
    FILE *fpScores;
    int r, c;
    // Statements
    fpScores = fopen( "scores.txt", "r" );
    int numOfDivers = 0;
    fscanf(fpScores, "%d", &numOfDivers);
    printf("The numbers of divers is %d.\n\n", numOfDivers);
    for (r = 0; r < MAX_ROWS; r++)
    printf("PIN DIF J1 J2 J3 J4 J5 J6 J7\n");
    printf("=== === == == == == == == ==\n");
    fscanf(fpScores, "%lf", &diverId[r]);
    printf("%.1lf ", diverId[r]);
    if( ( r + 1 ) % lineSize == 0 )
    printf( "\n");
    printf("\n");
    ...end of function
    The problem is that the for loop goes through the file and makes every value have its own row like this:
    1111
    1.5
    5.4
    6.0
    etc..
    Any help with be appreciated. Thanks!
  3. Oct 10, 2009 #2
    Code (Text):
    [b]for (r = 0; r < MAX_ROWS; r++) // I assume this is mistakenly placed here (it shouldn't be here)[/b]
    printf( "\n");
    I would run this code in a debugger and see why ( r + 1 ) % lineSize always returns 0.
    Personally though i would have actually used a for loop within a for loop for this..
    eg.
    Code (Text):
    for (l = 0; l < lineSize ; l++)
    fscanf(fpScores, "%lf", &diverId[l]);
    printf("%.1lf ", diverId[l]);
    printf("\n");
    As the line is completely read, it will print a new line.
    It will then repeat for the next line.
    This is only a one dimension array though, so the array will get reused for each line (previous line data will be wiped from the array).
    I am not quite certain how you want the data stored within the array though..
    you could store it in a 2D array like diverId[r][l], it would still work the same. But i gather thats what scores[][] is for. You could get away with not using diverId[l] at all but it depends on the criteria of the program. I will leave that up to you :)
Similar Discussions: Help with C programming lab
  1. C program help (Replies: 5)
  2. C++ program help! (Replies: 1)
  3. C program help needed (Replies: 3)
Loading...
