Help with Chain Rule: Step by Step Explanation
In summary, the conversation discusses the application of the chain rule and partial derivatives in solving equations involving variables p, V, and T. The steps in between involve taking the derivative with respect to each variable and then summing them, which is similar to the product rule. The concept of differentials is also mentioned, which is a term that is helpful in solving differential equations but is not rigorously defined in standard calculus.
wumple
60
I'm looking at one step in my thermodynamics book and they go from
[tex] pV = \nu*R*T [/tex]
to
[tex] p*dV + V*dp = \nu * R * dT[/tex]
I think there's an application of the chain rule in here but I don't see exactly how it's working. Could someone show me the steps in between?
Thanks!
It is a partial derivative. You are allowing P,V,and T to very.
So in partial derivatives you can take the derivative with respect to one variable and then the derivative with respect to the next variable and so on. The sum of this being your answer. That is how you get that equation.
P(n,V,T) Derivative with respect to P= dP*V, the derivative with respect to V= dV*P and derivative with respect to T= n*R*dT.
So you end up with dP*V+dv*P=n*R*dT.
In a sense, this can also be thought of as being an application of the product rule. :biggrin:
thanks! I see it now
Actually now I'm looking back at this and I'm not sure I follow exactly what you mean. What are you taking the derivative of? Each side independently and then summing them? As in...
[tex] \frac {\partial} {\partial p} (pv) [/tex]
and then
[tex] \frac {\partial} {\partial v} (pv) [/tex]
etc...and then summing the results, keeping everything on the original side?
Then why do you get dp * v? I always learned that that would be
[tex] \frac {\partial} {\partial p} (pv) = v [/tex]
Where did the dp come from?
Thanks!
There is NO derivative with respect to "p" or "V". If pV= NRT and p, V, and T are functions (N and R are constants, of course) of some independent variable, x (whatever it is- I started to write t for time but this is true for any parameter) then differentiating both sides with respect to x,
[tex]\frac{d(pV)}{dx}= \frac{d(NRT)}{dx}[/tex]
then, using the product rule, not the chain rule,
[tex]p\frac{dV}{dx}+ \frac{dp}{dx}V= NR\frac{dT}{dx}[/tex]
which, in "differential notation", is
[tex]pdV+ Vdp= NRdT[/tex]
Oh! ok that makes sense. But then what exactly do you mean by 'differential notation'? I see that if you 'multiply' by dx then that's what you get, but I know that that isn't really very rigorous and not completely correct since a differential isn't a fraction. Does the "[tex]d[/tex]" mean in general a derivative with respect to some arbitrary independent variable? I always thought it was an infinitesimal.
Technically, I think the concept of a differential instead of just a "fraction" of differentials has been rigourized in Infinitesimal Analysis. Yes, it's an infinitesimal, I think. Technically, without infinitesimal analysis, your first post is not rigorous, making this whole thread just pure gobbledygook. I've always thought of the differential as a term (technically an infinitesimal) since it's so helpful for some differential equations.
On the other hand, to make "infinitesmal analysis" rigorous requires some rather deep symbolic logic. Most Calculus texts, after defining the derivative "dy/dx", which is NOT defined as a fraction but as a limit of fractions, then define the "differentials" dy and dx by taking "dx" as purely symbolic (avoiding any mention of "infinitesmal") and defining dy as (dy/dx) dx.
Actually, there is no need for Non Standard Analysis here at all. The differential df of a function f is well defined without it; if you study differential geometry you will learn what the symbols dp, dV, dT in your equation actually mean. They are 1-forms, which are linear functions on tangent vectors; i.e they are elements of the dual space to the space of tangent vectors at a point.
More specifically, the differential df of a function f is the 1-form which assigns to any vector field x the number x(f). Differentials are rarely rigorously defined in an introductory calculus sequence as they require a different way of thinking about geometry which would confuse new students, and frankly it is unnecessary to have them formally introduced at that stage. So don't worry about it too much, just treat them using the same rules as derivatives and you'll be fine
What is the chain rule?
The chain rule is a mathematical rule that allows us to find the derivative of a composite function. It is used when a function is composed of two or more functions nested within each other.
Why is the chain rule important?
The chain rule is important because it allows us to find the rate of change of a composite function, which is often needed in real-life applications. It is also an essential tool in calculus and is used to solve more complex problems.
What is the formula for the chain rule?
The formula for the chain rule is (f(g(x)))' = f'(g(x)) * g'(x). This means that the derivative of a composite function is equal to the derivative of the outer function evaluated at the inner function, multiplied by the derivative of the inner function.
How do you apply the chain rule?
To apply the chain rule, you first need to identify the outer function and the inner function of the composite function. Then, take the derivative of the outer function and substitute the inner function into it. Finally, multiply this result by the derivative of the inner function.
Can you provide an example of using the chain rule?
Sure, let's say we have the function f(x) = (3x+1)^2. The outer function is (3x+1)^2 and the inner function is 3x+1. Using the chain rule, we can find the derivative as follows: f'(x) = 2(3x+1)*(3) = 6(3x+1) = 18x+6.
  • Differential Geometry
  • Calculus
  • Calculus
  • Science and Math Textbooks
  • Differential Equations
