Circular Motion: Constant Centripetal Force and Velocity
In summary, the centripetal force at the bottom of the loop is always mg and the centripetal acceleration is 9.81m/s^2.
Jimmy87
686
Assessing the required forces at the top and bottom of a loop de loop. I understand that you need a larger force at the bottom of the loop because you have to counter gravity. My question is, when you are undergoing uniform circular motion and your centripetal acceleration is constant then would your centripetal force also be constant?
If you have a loop de loop with a centripetal acceleration of 9.81m/s^2 then at the bottom the reaction force is 2mg which provides the centripetal force but at the top the weight provides the centripetal force which is only mg as the reaction force would be zero. But if v^2/r is constant then how can the centripetal force be different at the top and bottom?
F = mv^2/r.
Have listed my thoughts in the top section.
Why do you assume constant speed? What is the effect of gravity on the motion around the loop?
Sorry, I meant to say that if we are purely considering uniform circular motion on a loop de loop where we have a centripetal acceleration of 9.81. Gravity acts against the centripetal force at the bottom but provides it at the top. I thought the reaction force provides the centripetal force at the bottom but then I don't get how the centripetal force can be greater at the bottom if the acceleration is constant? Or is the centripetal force not the whole force but just the net bit towards the centre?
How can you have uniform circular motion on a vertical loop? Do you consider some engine attached to the object moving around the loop?
The usual situation assumes a ball sliding freely around the loop. When it moves upwards it slows down, have a minimum velocity at the top and then accelerates again when it goes down.
So neither speed nor centripetal acceleration is constant for this motion.
Thanks for the reply. Ok forget that I see what you mean and take your point. What happens if you take a rope and a bucket with water in it. If you knew the radius and the mass then you could swing it with a constant velocity (v) such that the centripetal acceleration is 9.81 all the time. At the bottom the normal force from the bucket on the water would be 2mg and at the top it would be zero. Here the centripetal acceleration would be constant but wouldn't the force be greatest at the bottom?
Also, if the rollercoaster does indeed move at different speeds, would this strictly be non-uniform circular motion?
Ok, i see that you are really focused on constant speed. Then indeed the centripetal acceleration will be constant as well. And so will be the centripetal force. IF you can arrange this.
If you want the centripetal force to be equal with the weight of the ball, the reaction at the top will be zero. This is actully the limiting case for speed at the top. Any speed less than this will requir negative reaction force.
Likes Jimmy87
Thanks nasu. So, in my example, am I correct in saying that the reaction force of the bucket at the bottom of the swing will be 2mg but the centripetal force at the bottom will be mg? What I am trying to get at - is the centripetal force just the net force towards the centre as appose to the total force towards the centre? And would this mean that you should never label a FBD with the centripetal force as it is a net force only?
Also is it only true that the magnitude of the centripetal acceleration and force is constant since the direction is changing?
Jimmy87 said:
Thanks for the reply. Ok forget that I see what you and take your point. What happens if you take a rope and a bucket with water in it. If you knew the radius and the mass then you could swing it with a constant velocity (v) such that the centripetal acceleration is 9.81 all the time. At the bottom the normal force from the bucket on the water would be 2mg and at the top it would be zero. Here the centripetal acceleration would be constant but wouldn't the force be greatest at the bottom?
Correct. Centripetal force is the force required to cause the bucket to move in a circular path. It doesn't matter what other forces act on the bucket as long as the net force is mv^2/r.
There are two forces acting on the bucket.
1) The tension in the rope T which will vary
2) Gravity
In order to move in a circle the two components must sum to mv^2/r
Lets call the net force acting towards the center F
At the top
F = T + mg (they act in same direction)
For circular motion F must equal mv^2/r so
mv^2/r = T + mg
Rearrange to give a general equation for the tension..
T = mv^2/r - mg
If you then arrange for the velocity and radius to be such that mv^2/r = mg then T=0
At the bottom
F = T - mg (they act in opposite directions)
For circular motion F must = mv^2/r so
mv^2/r = T - mg
T = mv^2/r + mg
If you then arrange for the velocity and radius to be such that mv^2/r = mg then T=2mg
So the tension in the string varies top to bottom but in both cases the net force F = mv^2/r
Likes Jimmy87
2) Gravity
At the top
mv^2/r = T + mg
T = mv^2/r - mg
At the bottom
mv^2/r = T - mg
T = mv^2/r + mg
Perfect, thank you very much, that makes complete sense. So in the situation I described where you try to keep the velocity at a particular constant value such that the centripetal acceleration is always 9.81 then the magnitude of the centripetal force will be mg at every point around the circle? Is that right? Also, since the centripetal force is a net force is it wrong to label it in a FBD?
What is circular motion and how does it differ from linear motion?
Circular motion is when an object moves in a circular path around a fixed point, while linear motion is when an object moves in a straight line. In circular motion, the direction of the object is constantly changing, while in linear motion, the direction remains constant.
What is the role of centripetal force in circular motion?
Centripetal force is the force that acts towards the center of the circle, keeping an object in circular motion. Without centripetal force, the object would continue moving in a straight line.
What factors affect the speed of an object in circular motion?
The speed of an object in circular motion is affected by the radius of the circle, the mass of the object, and the strength of the centripetal force acting on the object.
How is angular velocity related to linear velocity in circular motion?
Angular velocity is the rate at which an object rotates around a fixed point, while linear velocity is the rate at which an object travels in a straight line. In circular motion, the two are related by the formula v = rω, where v is linear velocity, r is the radius of the circle, and ω is angular velocity.
What are some real-life examples of circular motion?
Some examples of circular motion in everyday life include the rotation of a ceiling fan, the orbit of the moon around the Earth, and the motion of a car around a roundabout. Ferris wheels, carousels, and satellite orbits are also examples of circular motion.
