Fortran Help with fortran code
  1. Sep 8, 2014 #1
    Hey everybody, I am a mechanical engineer and new to Fortran(I have decent experience in programming in C, Matlab and understand languages similar to them). However the Fortran programming structure is new to me. Hence I am facing problems debugging a Fortran code.
    Here is the link of the code which I want to run.
    http://www2.meteo.uni-bonn.de/forsch...rtran/coad1d.f [Broken]
    I am using a Plato Fortran Compiler.
    It runs without showing error, but when I enter the values initially asked, the program stops mid-way showing an error:
    Run-time Error
    *** Error 112, Reference to undefined variable, array element or function result (/UNDEF)
    COURANT - in file help.for at line 149 [+01de]
    main - in file help.for at line 45 [+05dc]
    So there is an error in the Courant subroutine or error in calling it. Again i am a little unfamiliar to fortran subroutines but is it possible for any of you to also check what the problem here is ???
    As far as i could see the variables inside the subroutine were declared beforehand. And the logic looks correct.
    Also is the declaration line 45 calling courant subroutine done correctly ???
    Any help is appreciated. I have already received awesome help from you all here.
  3. Sep 8, 2014 #2
    Mark44
    Staff: Mentor
    I can't get the link to open (HTTP 404 Not Found error). Please post the code directly in this page.
  4. Sep 8, 2014 #3
    Mark44, here it is:(it is huge)
    program coad1d
    parameter (n=400)
    implicit double precision (a-h,o-z)
    common /const/ rq0,dlnr,scal,ax
    common /cour/ c(n,n),ima(n,n)
    common /grid/ g(n),r(n),e(n)
    common /kern/ ck(n,n),ec(n,n)
    dimension rri(n),eei(n)
    data emin,pi,tmax/1.e-9,3.141592654,3600./
    c dt : time step (input in sec)
    c g : spectral mass distribution (mg/cm**3)
    c e : droplet mass grid (mg)
    c r : droplet radius grid (um)
    c dlnr: constant grid distance of logarithmic grid
    c rq0 : mode radius of initial distribution (input in um)
    c xmw : total water content (input in g/m**3)
    c xn0 : mean initial droplet mass (mg)
    c xn1 : total initial droplet number concentration (1/cm^3)
    c ax : growth factor for consecutive masses
    c scal: scaling factor for calculation of ax, see below
    c isw : collision kernel: 0 (long), 1 (hall), 2 (golovin)
    c read input variables
    print *,'enter dt,rq0,xmw,scal,isw'
    read *,dt,rq0,xmw,scal,isw
    rq0=rq0*1.e-04
    xmw=xmw*1.d-3
    xn0=4./3.*pi*1000.*exp(log(rq0)*3.)
    xn1=xmw/xn0
    dlnr=dlog(2.d0)/(3.*scal)
    ax=2.d0**(1.0/scal)
    c mass and radius grid
    e(1)=emin*0.5*(ax+1.)
    r(1)=1000.*dexp(dlog(3.*e(1)/(4.*pi))/3.)
    do i=2,n
    e(i)=ax*e(i-1)
    r(i)=1000.*dexp(dlog(3.*e(i)/(4.*pi))/3.)
    enddo
    c initial mass distribution
    x0=xn1/xn0
    do i=1,n
    x1=e(i)
    g(i)=3.*x1*x1*x0*dexp(-x1/xn0)
    enddo
    c courant numbers
    call courant
    c kernel
    call trkern (isw)
    c output for plotting
    do i=1,n
    rri(i)=min(1.d38,r(i))
    eei(i)=min(1.d38,e(i))
    enddo
    open (16,file='boplot00.out',status='old')
    write (16,6100) rri,eei
    6100 format (5e16.8)
    c nt: number of iterations
    nt=int(tmax/dt)
    c multiply kernel with constant timestep and logarithmic grid distance
    do i=1,n
    do j=1,n
    ck(i,j)=ck(i,j)*dt*dlnr
    enddo
    enddo
    c time integration
    tlmin=1.d-6
    t=1.d-6
    lmin=0
    do ij=1,nt
    t=t+dt
    tlmin=tlmin+dt
    c collision
    call coad
    if (tlmin.ge.60.) then
    tlmin=tlmin-60.
    lmin=lmin+1
    print *,'time in minutes:',lmin
    write (16,6100) t,g
    c mass balance
    x0=0.
    x1=0.
    do i=1,n
    x0=x0+g(i)*dlnr
    x1=max(x1,g(i))
    if (dabs(x1-g(i)).lt.1.d-9) imax=i
    enddo
    print *,'mass ',x0,'max ',x1,'imax ',imax
    endif
    enddo
    close (16)
    stop 'stop coad1d'
    end
    subroutine coad
    c collision subroutine, exponential approach
    parameter (n=400)
    data gmin /1.d-60/
    c lower and upper integration limit i0,i1
    do i=1,n-1
    i0=i
    if (g(i).gt.gmin) go to 2000
    enddo
    2000 continue
    do i=n-1,1,-1
    i1=i
    if (g(i).gt.gmin) go to 2010
    enddo
    2010 continue
    do i=i0,i1
    do j=i,i1
    k=ima(i,j)
    kp=k+1
    x0=ck(i,j)*g(i)*g(j)
    x0=min(x0,g(i)*e(j))
    if (j.ne.k) x0=min(x0,g(j)*e(i))
    gsi=x0/e(j)
    gsj=x0/e(i)
    gsk=gsi+gsj
    g(i)=g(i)-gsi
    g(j)=g(j)-gsj
    gk=g(k)+gsk
    if (gk.gt.gmin) then
    x1=dlog(g(kp)/gk+1.d-60)
    flux=gsk/x1*(dexp(0.5*x1)-dexp(x1*(0.5-c(i,j))))
    flux=min(flux,gk)
    g(k)=gk-flux
    g(kp)=g(kp)+flux
    endif
    enddo
    enddo
    return
    end
    subroutine courant
    parameter (n=400)
    do i=1,n
    do j=i,n
    x0=e(i)+e(j)
    do k=j,n
    if (e(k).ge.x0.and.e(k-1).lt.x0) then
    if (c(i,j).lt.1.-1.d-08) then
    kk=k-1
    c(i,j)=dlog(x0/e(k-1))/(3.d0*dlnr)
    else
    c(i,j)=0.
    kk=k
    endif
    ima(i,j)=min(n-1,kk)
    go to 2000
    endif
    enddo
    2000 continue
    c(j,i)=c(i,j)
    ima(j,i)=ima(i,j)
    enddo
    enddo
    return
    end
    subroutine trkern (isw)
    parameter (n=400)
    common /veloc/ winf(n),rr(n)
    dimension cck(n,n)
    data pi/3.141592654/
    c terminal velocity
    call fallg
    if (isw.eq.0) then
    c long kernel
    do j=1,n
    do i=1,j
    if(r(j).le.50.) then
    effi=4.5d-4*r(j)*r(j)*
    & (1.d0-3.d0/(max(3.d0,dble(r(i)))+1.d-2))
    else
    effi=1.d0
    endif
    cck(j,i)=pi*(rr(j)+rr(i))*(rr(j)+rr(i))*effi*
    & abs(winf(j)-winf(i))
    cck(i,j)=cck(j,i)
    enddo
    enddo
    elseif (isw.eq.1) then
    c hall kernel
    call effic
    do j=1,n
    do i=1,j
    cck(j,i)=pi*(rr(j)+rr(i))*(rr(j)+rr(i))*ec(j,i)*
    cck(i,j)=cck(j,i)
    enddo
    enddo
    else
    c golovin kernel
    do j=1,n
    do i=1,j
    cck(j,i)=1.5*(e(j)+e(i))
    cck(i,j)=cck(j,i)
    enddo
    enddo
    endif
    c two-dimensional linear interpolation of kernel
    do i=1,n
    do j=1,n
    jm=max0(j-1,1)
    im=max0(i-1,1)
    jp=min0(j+1,n)
    ip=min0(i+1,n)
    ck(i,j)=0.125*(cck(i,jm)+cck(im,j)+cck(ip,j)+cck(i,jp))
    & +.5*cck(i,j)
    if (i.eq.j) ck(i,j)=0.5*ck(i,j)
    enddo
    enddo
    return
    end
    subroutine fallg
    c terminal velocity of falling drops
    parameter (n=400)
    dimension b(7),c(6),rat(20),r0(15),ecoll(15,20)
    data b /-0.318657e1,0.992696,-0.153193e-2,-0.987059e-3,
    & -0.578878e-3,0.855176e-4,-0.327815e-5/
    data c /-0.500015e1,0.523778e1,-0.204914e1,0.475294,-0.542819e-1,
    & 0.238449e-2/
    data pi /3.141592654/
    eta=1.818e-4
    xlamb=6.62e-6
    rhow=1.
    rhoa=1.225e-3
    grav=980.665
    cunh=1.257*xlamb
    t0=273.15
    sigma=76.1-0.155*(293.15-t0)
    stok=2.*grav*(rhow-rhoa)/(9.*eta)
    stb=32.*rhoa*(rhow-rhoa)*grav/(3.*eta*eta)
    phy=sigma*sigma*sigma*rhoa*rhoa/((eta**4)*grav*(rhow-rhoa))
    py=phy**(1./6.)
    c rr: radius in cm-units
    do j=1,n
    rr(j)=r(j)*1.e-4
    enddo
    do j=1,n
    if (rr(j).le.1.e-3) then
    winf(j)=stok*(rr(j)*rr(j)+cunh*rr(j))
    elseif (rr(j).gt.1.e-3.and.rr(j).le.5.35e-2) then
    x=log(stb*rr(j)*rr(j)*rr(j))
    y=0.
    do i=1,7
    y=y+b(i)*(x**(i-1))
    enddo
    xrey=(1.+cunh/rr(j))*exp(y)
    winf(j)=xrey*eta/(2.*rhoa*rr(j))
    elseif (rr(j).gt.5.35e-2) then
    bond=grav*(rhow-rhoa)*rr(j)*rr(j)/sigma
    if (rr(j).gt.0.35) bond=grav*(rhow-rhoa)*0.35*0.35/sigma
    x=log(16.*bond*py/3.)
    y=0.
    do i=1,6
    y=y+c(i)*(x**(i-1))
    enddo
    xrey=py*exp(y)
    if (rr(j).gt.0.35) winf(j)=xrey*eta/(2.*rhoa*0.35)
    endif
    enddo
    return
    end
    subroutine effic
    c collision efficiencies of hall kernel
    parameter (n=400)
    dimension rat(21),r0(15),ecoll(15,21)
    data r0 /6.,8.,10.,15.,20.,25.,30.,40.,50.,
    & 60.,70.,100.,150.,200.,300./
    data rat /0.,0.05,0.1,0.15,0.2,0.25,0.3,0.35,0.4,0.45,0.5,
    & 0.55,0.6,0.65,0.7,0.75,0.8,0.85,0.9,0.95,1.0/
    data ecoll /
    & 0.001,0.001,0.001,0.001,0.001,0.001,0.001,0.001,0.001,0.001
    & ,0.001,0.001,0.001,0.001,0.001,0.003,0.003,0.003,0.004,0.005
    & ,0.005,0.005,0.010,0.100,0.050,0.200,0.500,0.770,0.870,0.970
    & ,0.007,0.007,0.007,0.008,0.009,0.010,0.010,0.070,0.400,0.430
    & ,0.580,0.790,0.930,0.960,1.000,0.009,0.009,0.009,0.012,0.015
    & ,0.010,0.020,0.280,0.600,0.640,0.750,0.910,0.970,0.980,1.000
    & ,0.014,0.014,0.014,0.015,0.016,0.030,0.060,0.500,0.700,0.770
    & ,0.840,0.950,0.970,1.000,1.000,0.017,0.017,0.017,0.020,0.022
    & ,0.060,0.100,0.620,0.780,0.840,0.880,0.950,1.000,1.000,1.000
    & ,0.030,0.030,0.024,0.022,0.032,0.062,0.200,0.680,0.830,0.870
    & ,0.900,0.950,1.000,1.000,1.000,0.025,0.025,0.025,0.036,0.043
    & ,0.130,0.270,0.740,0.860,0.890,0.920,1.000,1.000,1.000,1.000
    & ,0.027,0.027,0.027,0.040,0.052,0.200,0.400,0.780,0.880,0.900
    & ,0.940,1.000,1.000,1.000,1.000,0.030,0.030,0.030,0.047,0.064
    & ,0.250,0.500,0.800,0.900,0.910,0.950,1.000,1.000,1.000,1.000
    & ,0.040,0.040,0.033,0.037,0.068,0.240,0.550,0.800,0.900,0.910
    & ,0.950,1.000,1.000,1.000,1.000,0.035,0.035,0.035,0.055,0.079
    & ,0.290,0.580,0.800,0.900,0.910,0.950,1.000,1.000,1.000,1.000
    & ,0.037,0.037,0.037,0.062,0.082,0.290,0.590,0.780,0.900,0.910
    & ,0.950,1.000,1.000,1.000,1.000,0.037,0.037,0.037,0.060,0.080
    & ,0.290,0.580,0.770,0.890,0.910,0.950,1.000,1.000,1.000,1.000
    & ,0.037,0.037,0.037,0.041,0.075,0.250,0.540,0.760,0.880,0.920
    & ,0.950,1.000,1.000,1.000,1.000,0.037,0.037,0.037,0.052,0.067
    & ,0.250,0.510,0.770,0.880,0.930,0.970,1.000,1.000,1.000,1.000
    & ,0.037,0.037,0.037,0.047,0.057,0.250,0.490,0.770,0.890,0.950
    & ,1.000,1.000,1.000,1.000,1.000,0.036,0.036,0.036,0.042,0.048
    & ,0.230,0.470,0.780,0.920,1.000,1.020,1.020,1.020,1.020,1.020
    & ,0.040,0.040,0.035,0.033,0.040,0.112,0.450,0.790,1.010,1.030
    & ,1.040,1.040,1.040,1.040,1.040,0.033,0.033,0.033,0.033,0.033
    & ,0.119,0.470,0.950,1.300,1.700,2.300,2.300,2.300,2.300,2.300
    & ,0.027,0.027,0.027,0.027,0.027,0.125,0.520,1.400,2.300,3.000
    & ,4.000,4.000,4.000,4.000,4.000/
    c two-dimensional linear interpolation of the collision efficiency
    do j=1,n
    do i=1,j
    do k=2,15
    if (r(j).le.r0(k).and.r(j).ge.r0(k-1)) then
    ir=k
    elseif (r(j).gt.r0(15)) then
    ir=16
    elseif (r(j).lt.r0(1)) then
    ir=1
    endif
    enddo
    rq=r(i)/r(j)
    do kk=2,21
    if (rq.le.rat(kk).and.rq.gt.rat(kk-1)) iq=kk
    enddo
    if (ir.lt.16) then
    if (ir.ge.2) then
    p=(r(j)-r0(ir-1))/(r0(ir)-r0(ir-1))
    q=(rq-rat(iq-1))/(rat(iq)-rat(iq-1))
    ec(j,i)=(1.-p)*(1.-q)*ecoll(ir-1,iq-1)+
    & p*(1.-q)*ecoll(ir,iq-1)+
    & q*(1.-p)*ecoll(ir-1,iq)+
    & p*q*ecoll(ir,iq)
    else
    ec(j,i)=(1.-q)*ecoll(1,iq-1)+q*ecoll(1,iq)
    endif
    else
    ek=(1.-q)*ecoll(15,iq-1)+q*ecoll(15,iq)
    ec(j,i)=min(ek,1.d0)
    endif
    ec(i,j)=ec(j,i)
    if (ec(i,j).lt.1.e-20) stop 99
    enddo
    enddo
    return
    end
  5. Sep 8, 2014 #4
    Mark44
    Staff: Mentor
    Isn't this the same question you asked at the end of your other thread? If so, I posted what I think might be wrong in that thread.
  6. Sep 8, 2014 #5
    jtbell
    Staff: Mentor
