How Long Does a Jumping Fish Take to Pass a Point Above Water?
  • Thread starter CaveatLector
  • Tags
    Freefall
In summary, the fish jumps out of the water with a speed of 4.5 m/s and it takes 0.459 seconds for it to pass a point 0.4 m above the water.
CaveatLector
A fish is able to jump vertically out of the water with a speed of 4.5 m/s. How much time does it take for the fish to pass a point 0.4 m above the water on the way down?
Can someone please post how to do this? I know you need to solve for t by using the quad. equation but I have done it many times and cannot get the correct answer. Can someone please post a step by step solution so I can see where I am going wrong? Thanks in advance.
We don't do that here.
However, if you show the work you've already done on this problem, people will point out your mistakes and help you solve your own problem.
Okay
the equation i used was y-yo=vot+(1/2)at^2.
yo is zero because the fish starts at the water.
y is the distance that the problem gives you which is .4m.
a is 9.81, which is gravity.
vo is 4.5m/s.
But I am stuck. Do you use -9.81 since the fish is falling or do you first have to solve for the time it takes to go all the way up to zero velocity and then solve again for time to get to .4m above the water and add that number to the previous up to zero velocity?
Yes, the acceleration due to gravity will be negative if you use up as a positive reference. So, you'll get a quadratic with two answers, and pick the larger one.
You need to know that the direction of the acceleration is not positive, but negative if your velocity is positive.
Also, you might want remember that your equation should yield two answers and you have to know which one to use for the fish 'falling' past 0.4m
CaveatLector said:
...do you first have to solve for the time it takes to go all the way up to zero velocity and then solve again for time to get to .4m above the water and add that number to the previous up to zero velocity?
I think you've got the right idea.
You want to split it into two problems; one for going up, and the other for coming back down.
No, no. You only need to use the function for displacement.
Using the formula I posted above I still get the wrong answer. I just plug the numbers in and solve for t right? I'm a little confused as to whether I need to approach the problem differently. Do I need to do 2 separate calculations, one for the the fish going up and then one for it coming down?
Did you get .819s?
Show us what you did.
Yes that is what I got but it's wrong. So I'm doing something wrong here.
Seems like I would need more info to solve this problem than what I have been given in the problem. Too many variables?
you have enough information to use the equations
Well what am I doing wrong? Is it a 2 part problem?
I'll give you a dollar if I can have your brain.
a=4.905 or -4.905?
b= 4.5
c= .4
plug those into quadratic eq.?
Huh? What's their answer?
Nevermind. I figured it out. Use velocity formula to find time at zero v. Use that time to solve for distance traveled at 4.5m/s over the t of .459. Then do the freefall formula to solve for time at .4m then add that time to previous t solved for. It worked. Makes sense intellectually, just needed to figure out the logistics of how to approach it. Thanks.
1. What is freefall?
Freefall is the motion of an object in which gravity is the only force acting on it. This means that the object is accelerating towards the Earth at a constant rate of 9.8 meters per second squared.
2. How do I solve a freefall problem?
To solve a freefall problem, you will need to use the equation: d = 1/2gt^2, where d is the distance traveled, g is the acceleration due to gravity, and t is the time. You will also need to consider the initial velocity and direction of the object.
3. What units should I use when solving a freefall problem?
When solving a freefall problem, it is important to use consistent units. The most commonly used units are meters for distance, seconds for time, and meters per second squared for acceleration.
4. How does air resistance affect freefall?
Air resistance, also known as drag, can affect the motion of an object in freefall. It acts in the opposite direction of the object's motion and can slow down its acceleration. However, in most freefall problems, air resistance is not considered unless specified.
5. Can freefall occur in space?
In a vacuum, there is no air resistance, so objects will continue to accelerate due to gravity until they reach a point of equilibrium or collide with another object. Therefore, freefall can occur in space as long as there is a force of gravity acting on the object.
