Homework Help: Help with functional equation
  1. May 16, 2012 #1
    A function from R-->R is differentiable and follows f( (x+y)/3 ) =( 2 + f(x) + f(y) ) / 3
    Derivative of f(x) at x=2 is 2
    Find the range of f ( |x| )
    2. Relevant equations
    3. The attempt at a solution
    Well the questions asks me the range of f( |x| ). But i don't even know f(x). I did find the value of f(0) which is 2. And i don't know what to do afterwards. I have no idea why the value of derivative is given.
  3. May 16, 2012 #2
    SammyS
    Staff Emeritus
    How is f(-x) related to f(x) ?
    Hint: Let y = -x .
    Use that result to see how f '(-x) is related to f '(x) .
  4. May 16, 2012 #3
    SammyS
    Staff Emeritus
    Two more substitutions that might be helpful:
    y = x (which you may have used to fin f(0) )
    and
    y = 2x .
  5. May 17, 2012 #4
    Ok (by using spoiler) f(0) = 2 + f(x) + f(-x) / 3
    => 6 = 2 + f(x) +f(-x)
    => 4 = f(x) +f(-x)
    Thus 0 = f '(x) - f '(-x)
    f '(x) = f '(-x)
    f '(x) is even so f(x) is odd.
    But if f(x) is odd then f(x) + f (-x) = 0 but i found out earlier that it is equal to 4. A bit confused
  6. May 17, 2012 #5
    SammyS
    Staff Emeritus
    If f(x) is odd, then it is true that f '(x) is even, but the converse is not necessarily true.
    If f '(x) is odd, then it does follow that f(x) is even.
    In your case, 4 = f(x) +f(-x), so that f(-x) = -f(x) + 4 . Therefore, f(x) is not odd.
    Consider the function g(x) defined as g(x) = f(x) - 2.
    g(x) is odd.
  7. May 17, 2012 #6
    Oh ok - but still i cannot solve the initial problem. This is what i have done till now:-
    f(0) = 2
    f(x) = f(-x) + 4 and f '(x) = f ' (-x)
    Are they right? and what else do i need to do?
  8. May 17, 2012 #7
    SammyS
    Staff Emeritus
    See what derivative relationships result from the above.
    Also, you might consider investigating the behavior of the function g(x) .
