• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Help with homework question
  • Thread starter nelly42688
1. A tennis ball is thrown from ground level with velocity directed above the horizontal. If it takes the ball 0.50 s to reach the top of its trajectory, what is the magnitude of the initial velocity? You should draw a diagram to show this problem in your explanations.
i no that Ax=0 Ay=-9.8 i have all the equations just I dont know which to use, once i figure taht out i should be fine any help would be great
LowlyPion
3,079
Welcome to PF.
If you know how long it took for acceleration to reduce the velocity to 0 at the top of the trajectory, then you know the vertical component of velocity.
v = a*t
You know a and t.
But without further info about what happens in the x direction or the angle, that's about all you can tell is the vertical component.
so basically magnitude would be 4.9m/s since your dividing gravity by .5?
or would it be 9.8 since the total flight path is 1 second... this is where i get confused
Now for finding the ragne i know the R= (VoCOS(30))T which in this case would be 8.5m
I know i didnt explain well how i got these figures but its hard to type it all out on a keyboard. any help would be great and thank you in advance
LowlyPion
3,079
This is correct.
LowlyPion
3,079
Now that you have revealed that the range is 8.5m then you can use the total time - which is twice the time to max height to determine the Vx. In this case since time is 1 sec, that makes Vx 8.5 m/s.
So there you have it.
The initial V is (Vx2 + Vy2)1/2
And if you didn't know θ, the angle is given by Vy/Vx = tanθ
Since it turns out you knew θ, you could have simply said 4.9 = Vo*sin30 or Vo = 2*4.9
Maybe next time post the whole problem?
ah sorry i thought i put θ in there, sorry about that but thank you so much for your help, you answered a lot of questions for me that i just didnt understand.
Related Threads for: Help with homework question
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
