Help with logarithms
  • Thread starter terps
Let r = log9 31, s = log6 31, t = log9 6.
Write the following expressions in terms of r, s, and/or t. The change of base formula may be helpful in finding some of these logarithms.
log 9 base 31
I am not sure where to begin. I am confident with the different rules for logarithms such as log 5 + log 4 = log 20, but i am not sure how to switch bases. I am sure it has something to do with the equation r= log 31 base 9. All i am asking for is a little guidance.
Answers and Replies
8,120
Does your book show the change-of-base formula?
Yes it does, but i thought that you could only do that when they have common bases. what i mean is that you can only use it for example log 5/log 3 since they have the common base 10. No?
8,120
The change-of-base formula can be used to change the base for any log expression with a reasonable base (base > 0, base != 1).
It's not clear to me what you need to do.
terps said:
log 9 base 31
Get rid of "base" in there, and use subscripts to indicate the base.
I can't tell if this is supposed to be log31 9 or log931.
If the advanced menu bar isn't showing at the top of the input window, click Go Advanced. From the advanced menu, click the X2 button, and it will add [ sub] [ /sub] tags, but without the leading spaces I show. The subscript should go between the two tags.
Similarly, you can get superscripts for exponents, by clicking the X2 button. That button puts in [ sup] [ /sup] tags (again, without the spaces), and you enter the exponent between the two tags.
Thank you for all of your help. I figured it out. the answer (per change of base formula) is log99/r. i was under the impression that we could only use the variables r s and t in our answer.
Related Threads on Help with logarithms
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
