• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Help with Minimum Area
  • Thread starter karisrou
1) A cardboard box of 32in^3 volume with a square base and open top is to be constructed. Find the minimum area of cardboard needed.
Since it has a square base, length and width must be the same, variable b for base.
So volume could be written as: hb^2=32 and surface area as b^2+4bh=min.
Once I get here, I''m not quite sure what to do.
Any help is greatly appreciated!
You want to get your minimum as a function of one variable. Use substitution to make that happen.
Alright cool. I've got b^2 + 128/b^2 = min
Should I take the derivative now?
Dick
26,258
618
You might want to make sure that's correct before you take the derivative. You've got h*b^2=32 and you want to minimize b^2+4*b*h. Are you sure that means b^2+128/b^2 should be minimized?
But aren't I supposed to substitute h into b2 + 4bh? and then solve for the critical point? Or would I just take the derivative of that? And then if thats what I'm supposed to do, do i take the derivative in relation to b or h?
Dick
26,258
618
You are supposed to do exactly that thing. But are you sure substituting h=32/b^2 into b^2+4hb gives you b^2+128/b^2?
Right, so b2 + 4b(32/b2)
Which simplifies to
b2 + 128b/b2
Which simplifies to
b2 + 128/b
Dick
26,258
618
so 2b - 128/b2
and then would you multiply everything by b2 to clear the denominator? giving you 2b3 - 128 = 0
So b = 3rt64
So 4?
Then if b = 4
h must equal 2, per substitution into the original equation.
So then the areas of the sides are 8, and the base is 16, so the total area is 8 x 4 + 16 = 48
Is this right?
Dick
26,258
618
It looks good to me. But I've made mistakes before. Never hurts to double check. Seem ok to you?
Yeah, everything looks right. Thanks very much for your help!
32,571
4,301
Which simplifies to
b2 + 128b/b2
Which simplifies to
b2 + 128/b
It would be a very good idea to work with equations, in part to help keep you focused on what you're doing.
You're trying to minimize the area as a function of b, or A(b) = b2 + 4b(32/b2) = b2 + 128/b
Then when you take the derivative, you get A'(b) = 2b - 128/b2
To find the critical point, you're going to set A'(b) to 0, so 2b - 128/b2 = 0
You can multiply both sides of that equation by b2 to get 2b3 - 128 = 0, and you can then solve that equation for b.
Related Threads for: Help with Minimum Area
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
