Step-by-Step Guide to Implicit Differentiation: Examples and Tips
  • Thread starter ph0bolus
  • Tags
    Homework
In summary: You forgot to continue with the rest of the chain rule ... it's not just the derivative of the outside function times the derivative of the inside function. You have to continue with the derivative of the inside function times the derivative of that function.So if y = f(g(x)), then y' = f'(g(x))g'(x)And you're not done yet because you're still differentiating the inside function. So you have to use the chain rule again.The next step would be to find the derivative of (x^2-5x)^5. That's the power rule times the derivative of the inside function, which is the chain rule.So it would be y' = -2(2x-
ph0bolus
31
I'm supposed to just differentiate these 2
1)http://img132.imageshack.us/img132/8439/img0543hd2.jpg
2)http://img142.imageshack.us/img142/8544/img0544sr0.jpg
And use implicit differentiation to fidn dy/dx on these 2
3)http://img511.imageshack.us/img511/3284/img0545gy6.jpg
4)http://img231.imageshack.us/img231/6163/img0546ew3.jpg
I took a crack at both of them the 1st two i couldn't really complete, and the last two I'm not really confident on them. Any help would be greatly appreciated.
Since you didn't do either of the first 2 correctly:
For 1) You didn't apply the chain rule right
For 2) You didn't apply the multiplication rule at all
For 3) What's [itex]\frac{d}{dx}(6)[/itex]?
For 4) You did fine until you didn't divide through totally properly on the second to last step.
You need to slow down when doing these problems.
[tex]\frac{d}{dx}(\sin x)=x'\cos x[/tex]
would the third one be
y'=-y^2-2xy/(x^2*2y)for the last one would it be
y'= 1-2y/2xy?
You factored a common term of y' incorrectly. Review your Algebra, it's not too late!
thanks..that helps a lot..ok reviewed it
3) y'=-y^2-2xy/x^2*2yx
4) y'=1-2y/2x2y
Let's do a review ... factor and solve for y:
[tex]y+3x+zy=xy[/tex]
sorry math and physics is not my forte
i guess the review problem would be
y=3x/xz?
[tex]a(x+y+z)=ax+ay+az[/tex]
Your mistake is that, you're not factoring out the common term ...
[tex]y-xy+zy=-3x[/tex]
Common term y
[tex]y(1-x+z)=-3x[/tex]
[tex]y=-\frac{3x}{1-x+z}[/tex]
Math wasn't my fav. subject either, but it's definitely useful so deal with it.
Notice on your 2nd to last line for your last problem ... you divided only the 1st 2 terms ... it has to be EVERYTHING!
damn..can't believe it was that simple i forgot about it maybe the "factor" was a dead giveaway.
So if i applied that to problems 3 & 4
3) y'=-y^2-2xy/x^2+2yx
4) y'=1-2y/2x+2y-1
please tell me i did it right..
Yes, those are good now.
Did you rework the first one?
When I do the chain rule of trigonometric functions, like in problem one, I always think of the regular function, sin x, with the stuff stuffed in, and then the derivative of the stuff.
As rocomath said d/dx[sin u] = (cos u) u'
G(x) = sin 3x and G'(x) = 3 cos 3x
u = 3x cos u = cos 3x
u' = d/dx [3x] = 3
Also, with trigonometry, it helps to pay attention to the parentheses.
Studying these may help quite a bit:
y = cos 3x^2 = cos (3x^2)
y' = (-sin 3x^2) (6x) = -6x sin 3x^2
y = (cos 3)x^2
y' = (cos 3) (2x) = 2x cos 3
y = cos (3x)^2 = cos(9x^2)
y' = (-sin 9x^2)(18x) = -18x sin 9x^2
y = cos^2 x = (cos x)^2
y' = 2(cos x) (-sin x) = -2 cos x sin x
yeah, i know how to do chain rule..
derive outside, leave inside, then derive outside, but since there's it's 3pi(x)/2 would i use the quotient rule or what. I know 3 pi/2 is a constant.
What is the derivative of kx if k is a constant? It's just k, no quotient rule needed for that. The chain rule is the derivative of the outside function times the derivative of the inside function.
Well, the chain rule is where the mistake is being made. You don't have to worry about the quotient rule.
Take a look at:
cos (3x^2)
IN problem one you posted, you have as the first "term" sin ((3 * pi * x) / 2) as the minuend.
So it's cos ((3 * pi * x)/2)
times the derivative of 3 * pi * x / 2.
You pull out the constant, which leaves you with the constant times the derivative of x, which is one.
So the first term is ((cos (3 * pi * x)/2) * 3 * pi)/2
You can do the other one the same way.
It helps to study example of the Chain Rule to master it. The Chain Rule is so important that you will seldom again differentiate any function without using it.
yeah i wrote it down wrong..
yeah I've had this it's what's next is what i have the problem on..
cos(3*pi*x/2)(3*pi/2)-sin(3*pi*x/2)(3*pi/2)
do i just leave it like that? or should i rearrange the constant to the front.
Doesn't matter ... it's still the same. However, it's customary to write the constant in the front. Also, in this case, they both have a common term of that same constant, so factoring it out would be the best choice.
[tex]y'=x'(\cos x-\sin x)[/tex]
Ok got it...
On the second one I used the chain rule and ended up with:
-2(2x-5)^-2 * (12x-30)(x^2-5x)^5
and now I'm stuck yet again.
What is implicit differentiation and when is it used?
Implicit differentiation is a mathematical technique used to find the derivative of a function that is defined implicitly by an equation. It is used when the function cannot be easily written in the form of y = f(x) and when the dependent variable is not explicitly stated in the equation.
What are some common examples of implicit differentiation?
Some common examples of implicit differentiation include finding the derivative of a circle, finding the slope of a tangent line to a curve, and finding the rate of change of a relationship between two variables.
What are the basic steps of implicit differentiation?
The basic steps of implicit differentiation include differentiating both sides of the equation with respect to the independent variable, using the chain rule when necessary, and isolating the derivative on one side of the equation.
What are some tips for solving implicit differentiation problems?
Some tips for solving implicit differentiation problems include clearly identifying the dependent and independent variables, using parentheses to avoid confusion, and simplifying the equation before differentiating. It is also helpful to practice and familiarize yourself with the basic rules of differentiation.
How is implicit differentiation different from explicit differentiation?
Implicit differentiation is used when the function is defined implicitly and the dependent variable is not explicitly stated, while explicit differentiation is used when the function is defined explicitly in terms of the independent and dependent variables. Implicit differentiation also requires the use of the chain rule, while explicit differentiation only requires the basic rules of differentiation.
