Homework Help: Help with Newton Question
  1. Oct 13, 2012 #1
    A tank in the form of a right-circular cone standing on end with its vertex down, is leaking water through a hole its circular bottom.
    • a. Suppose the tank is 20 feet high moreover has a radius 8 feet wide moreover the circular hole has a radius 2 inches. In problem 1.3 you were asked to demonstrate that the differential equation governing the height h of water leaking from a tank is
      dh/dt = -5/6h3/2
      In this model, friction as well as contraction of the water at the hole were taken into account with c = 0.3, moreover that g was taken to be 32 ft/s2. If the tank was initially full, how long shall it take the tank to empty?
      b. Suppose the tank has a vertex angle of 60o in addition that the circular hole has a radius of 2 inches. Determine the differential equation governing the height h of water. Use c = 0.6 as well as g = 32 ft/s2. If the height of the water is initially 9 feet, how long will it take the task to empty?
    2. Relevant equations
    dh/dt = -5/6h3/2
    3. The attempt at a solution
    Not yet. I just came into this site after being referred to by a friend, moreover I seriously need help in differential equations. Can someone help?
  3. Oct 14, 2012 #2
    Simon Bridge
    Welcome to PF;
    Solving the differential equation seems to be a matter of integration - applying the initial value.
    I look forward to seeing your initial attempts at the problem.
