Help with Oscillation Problem
  • Thread starter kittykatxox
  • Tags
    Oscillation
In summary, a 850 g block is attached to a vertical spring with a stiffness constant of 9N/m. The block is released at the position where the spring is unextended and falls into simple harmonic motion. The maximum extension of the spring can be calculated using the equation F = -kx, but this will only give the distance between the old and new equilibrium positions. To find the distance between the highest and lowest points, either the geometry of the motion or conservation of energy can be used. The value of ω can also be used to calculate the period of oscillation and the fraction of that period it takes for the mass to reach the lowest point.
a 850 g block is attached to a vertical spring whose stiffness constant is 9N/mThe block is released at the position where the spring is unextended. a) What is the maximum extension of the spring? b) How long does it take the block to reach the lowest point?
so I found w by using k=mw^2
9=0.85w^2
w=3.26 rad/s
next I found the max extension by using F=-(mw^2)x
(0.85*9.8)= -(0.85*(3.26)^2)x
x=0.93
I'm not sure what to do next, any help is appreciated
Thanks
9=0.85w^2
w=3.26 rad/s
Your ω looks pretty good. (Except for a minor rounding error. You might wish to check your significant figures.)
x=0.93
Sorry, :frown: but F = -kx, alone, isn't going to work for this problem all by itself. (Although you still might find it useful, so keep it in your back pocket.)
F = -kx would work if you were trying to find the distance between the old equilibrium position, before the mass was attached, to the new equilibrium position after the mass is attached.
But in this problem, the mass doesn't simply fall to the new equilibrium position and stay there. Instead it falls past the new equilibrium position and keeps going. Eventually, its velocity drops to zero for an instant, but it doesn't stop there! The spring then pulls the mass back up, again past the new equilibrium position, and eventually the mass stops back up at the top where it was initially released. The whole process then repeats. The block has gone into simple harmonic motion.
There are two ways to determine the distance from the highest position to the lowest position the mass reaches.
a. The first way is this: you could describe the geometry of this motion, and then deduce the peak-to-peak difference from that.
b. The second way is to use conservation of energy. Consider the two places in the oscillation where the velocity is zero (once at the top and once at the bottom). At both of these places, the kinetic energy of the mass is zero. Use conservation of energy, considering the gravitational potential energy, and the potential energy stored in the spring.
Thanks
Again, you'll have to redo your calculation of x, as I've discussed above. But you do have a good value for ω already! (Except for the minor rounding error.)
If you know ω, can you calculate the period, T of oscillation? If the mass starts at the top, what fraction of T does it take to get to the bottom? :wink:
What is an oscillation problem?
An oscillation problem is a type of mathematical problem that involves the behavior of a system over time. It typically refers to the repetitive back-and-forth motion of a system between two points or states.
What causes an oscillation problem?
An oscillation problem can be caused by a variety of factors, including external forces acting on the system, changes in the system's environment, or inherent properties of the system itself, such as elasticity or inertia.
How do you solve an oscillation problem?
Solving an oscillation problem involves identifying the specific system and its properties, setting up the appropriate equations or models, and using mathematical or computational methods to analyze the behavior of the system over time.
What are some real-life examples of oscillation problems?
Some examples of oscillation problems include the swinging of a pendulum, the vibrations of a guitar string, the motion of a mass on a spring, and the oscillations of an electronic circuit.
Why are oscillation problems important?
Oscillation problems are important because they allow us to understand and predict the behavior of systems in various fields, including physics, engineering, and biology. They also have practical applications, such as in designing stable structures and systems, and developing technologies like clocks and sensors.
Suggested for: Help with Oscillation Problem
