Solving Math Proofs: Get Help Quickly!
  • Thread starter Keyboard
  • Tags
    Proofs
In summary, we can prove that if 0<a<b, then a<\sqrt{}ab<a+b/2<b and \sqrt{}ab\leq(a+b)/2 holds for all a,b \geq 0 by squaring the given expressions and comparing them, taking into account that a and b are both positive. This manipulation of the inequality will show that the original inequality holds for the specified condition. Simply put, squaring does not change the direction of the inequality and makes it easier to work with.
Keyboard
1. prove that if 0<a<b, then
a<[itex]\sqrt{}ab<a+b/2<b[/itex]
2. [itex]\sqrt{}ab\leq(a+b)/2[/itex] holds for all a,b [itex]\geq 0[/itex]
3. Where do I begin? I have no clue! Thank you to anyone who can help!
Try squaring the various expressions and compare those: since a and b are both positive, the order of the inequalities will not be changed.
Thanks for the quick response, would you be able to elaborate a little bit more on what you said? I'm not looking for the answer, just a little more elaboration on what you posted.
Any help is appreciated!
#2 is probably easier to start with: what do you get when you square both sides of the inequality? In light of the fact that a and b are positive numbers, is it clear that that inequality works? If so, since the two sides of the inequality are the squares of the original sides of the inequality, the original inequality will also hold, for the specified condition.
This is not "all there is to it": you will have to manipulate the inequality in some way to arrive at an inequality you know must be true.
can you explain that in layman's terms?
If 0 < X ≤ Y , then X2 ≤ Y2 . Squaring does not change the direction of the inequality and the squared expressions may be easier to work with.
cool. that's really helpful, thanks
What is a math proof?
A math proof is a logical argument that demonstrates the truth of a mathematical statement or theorem. It involves using established mathematical principles and rules to logically show that a statement is true.
Why are math proofs important?
Math proofs are important because they provide a rigorous and systematic way to verify the validity of mathematical statements and theorems. They also help to deepen our understanding of mathematical concepts and can lead to new discoveries in mathematics.
What are some common strategies for solving math proofs?
Some common strategies for solving math proofs include working backwards from the desired conclusion, using logical reasoning, breaking down the problem into smaller steps, and looking for patterns or connections between different parts of the proof.
How can I get help quickly when solving math proofs?
One way to get help quickly when solving math proofs is to consult with a math teacher or tutor who has expertise in the specific area of mathematics. Online resources, such as forums and video tutorials, can also be helpful in providing guidance and clarification.
What are some tips for effectively communicating math proofs?
To effectively communicate math proofs, it is important to use precise language, clearly define any new terms or symbols, and provide explanations for each step in the proof. Visual aids, such as diagrams or graphs, can also be helpful in conveying complex concepts and relationships.
