What is the concept of quotient space and quotient groups?
In summary, the concept of a quotient space and quotient groups involves defining an equivalence relation on a set and looking at the equivalence classes of that relation. These classes can then be used to construct a new set with a specific binary operation, resulting in a quotient group or quotient space. This is useful in various mathematical concepts such as vector spaces and groups.
Coolphreak
46
I just wanted to know if someone can explain to me the basic concept of a quotient space and quotient groups.
Well, let ~ be an equivalence relation on S. For some x from S, the equivalence class of x is the class of all elements from S which are equivalent to x, i.e. [x] = {y from S : y ~ x}. The class of all equivalence classes in S is called the quotient class of S by ~, and is denoted S/~. This gives an outline of the idea - you need to have an equivalence relation defined.
So, if you have a subgroup H of a group G, and some elements a, b from G, define the relation "~r (~l) to be right (left) congruent modulo H", so that a~r b (mod H) if ab^-1 is in H (a~l b (mod H) is a^-1 b is in H). One can easily show that right (or left) congruence modulo H is an equivalence relation on G, and you may look at the equivalence classes of that relation (usually called cosets of H in G and denoted Ha (aH) for right (left)congruence modulo H). Now, if you have a normal subgroup N of G (left and right cosets coincide, eg the relations ~r and ~l coincide), it can be shown that G/N is a group (under a specific binary operation), and it's called the quotient group of G by N.
So, we started off with an equivalence relation, took its equivalence classes and defined a binary operation with aNbN = abN, and arrived at a (quotient) group G/N.
Edit:
It's even easier to do this for a vector space: let V be a vector space, and M some subspace of V. Define the relation ~ on V with (for x, y in V) x ~ y iff x - y is in M. It's easily verified that ~ is an equivalence relation. Again, look at the equivalence classes of this relation, and take the class of all the equivalence classes, eg V/~ = {[x] : x in in V} is called the quotient (vector) space with operations on equivalence classes defined with [x] + [y] = [x + y] and a[x] = [ax], where a is any scalar.
1. What is a quotient space?
A quotient space is a mathematical concept that involves creating a new space by identifying and collapsing certain parts of an existing space. It is often used in linear algebra and topology to study the properties of a given space.
2. How is a quotient space different from a subspace?
A subspace is a subset of a larger space that still retains all the properties of the larger space. A quotient space, on the other hand, is created by collapsing certain parts of a space, resulting in a new space with potentially different properties.
3. What is the purpose of using quotient spaces?
Quotient spaces allow us to study the properties of a given space in a simpler and more manageable way. They are often used in mathematics and physics to simplify complex systems and equations.
4. What are some common applications of quotient spaces?
Quotient spaces are commonly used in the fields of topology, group theory, and differential geometry. They have applications in areas such as data analysis, computer graphics, and machine learning.
5. How do you construct a quotient space?
To construct a quotient space, we first need to identify the elements or parts of the original space that we want to collapse. Then, we can define an equivalence relation on these elements, which will determine how they are identified in the new space. Finally, we can use this equivalence relation to partition the original space into equivalence classes, which will form the basis of the quotient space.
  • Linear and Abstract Algebra
  • Topology and Analysis
