Help with series
  1. Feb 10, 2009 #1
    Help with "series"
    so I have learned how to do different problems of series.
    but theres this problem that I spent hours last night but could not come up with anything.
    which is-
    n/2^(n-1)
    n=1
    so from there i was able to take out 2 and end up with: 2 n /(2^n)
    i dont know how to do after that. however, i thought about doing (1/2)^n but then again it does not make sense to me.
    help needed. i will appreciate that. thanks
  3. Feb 10, 2009 #2
    Tom Mattson
    Staff Emeritus
    Re: Help with "series"
    What are you supposed to do with it? I would assume you are supposed to determine if it converges, but unless you say I can't be sure. Also, please show us an attempt at the problem. Then we can help you with where you get stuck.
  4. Feb 11, 2009 #3
    Delphi51
    What an interesting piece of work! I wonder who thought that up. It's hypnotic.
    Of course it is easy to find the sum on a spreadsheet . . . approximately, I suppose.
    I decided it just HAD to be a telescopic series and played with it for a good long time before I found it. Is that enough of a hint?
    I started with the nth term written as the difference 4n over 2^n minus 2n over 2^n and then tried to write the 2nd term in the form of the first term with n replaced by n+1 as is required to collapse a telescopic series. Unfortunately that wasn't quite right and nothing I guessed was either. Finally I resorted to adding x to that first term and subtracting x from the second. To find x, I replaced n with n+1 in the first term and set it equal to the second. It came out very nicely and converges to 4 as the spreadsheet predicted, so I expect it is correct. I'm no mathematician, so this may not be the conventional way of summing this series.
    I hope I have not spoiled your fun with this intriguing series!
  5. Feb 11, 2009 #4
    Delphi51
    Oh, a nicer way to do it is to guess that the nth term is an+b over 2^n minus a(n+1)+b over 2^(n+1), where a and b are two parameters to be found. This setup guarantees that the series will be telescoping. Set that expression equal to 2n over 2^n and solve for a and b.
  6. Feb 11, 2009 #5
    Dick
    There's another way to think about it. Can you sum the series 1+x+x^2+x^3+...? Now think what happens if you take the derivative and substitute a special value of x.
  7. Feb 11, 2009 #6
    Delphi51
    That's quite a find, Dick! Glad you didn't mention it before I had all that fun finding the telescoping series.
  8. Feb 11, 2009 #7
    Dick
    It's just the 'standard' way to do it. Glad you had fun!
