Ozen
- 41
- 2
- TL;DR Summary
- I came up with a circuit to drive an LED, but some of the components will make it too large to fit in the device.
Attached is the schematic for the circuit. It uses a TPS61042DRBT LED driver along with a PSoC 4000 8pin microcontroller to drive a 10mA LED with push button controls for brightness. The problem is some components, like the inductor and sense resistor is way too large (over 6mm long!). This is supposed to fit into a micro reflex sight and uses a CR2032 battery, which already has a diameter of 22mm. The footprint it is housed in has a length of 47.5mm and a width of 25.4mm. The adjustment mechanism also takes up ~14mm. That leaves around 11.5mm of space (not including wall thickness) to fit a PCB with all this on it.
How in the world can I possibly shrink this system? I looked at alternative drivers and even linear drivers, but they all loop back into the problem of it doesn't fit my need; like incorrect output current that varies drastically with low voltages. Or in the rare cases it doesn't have that problem, it still requires these large components that just won't fit. The only thing I could think of is to have it have expanded across multiple PCB's that are stacked on top of each other, but that seems significantly more costly and becomes a mess of wires connecting PCB to PCB.
Any insight on this is greatly appreciated! Feel free to critique the circuit as well, this is my first completed circuit so I am sure it is mediocre.
