Spring Simple Harmonic Motion problem
In summary, in the first problem, a 15.0kg block is pulled by a massless, horizontal spring causing it to accelerate uniformly and reach a speed of 5m/s in .5s. The spring is stretched by .2m during this process. To find the spring constant, the equation F applied = -kx can be used. However, to find the coefficient of kinetic friction between the block and the table, the equation F applied = ma must be used instead. In the second problem, a 30.0kg block with a 15.0kg block on top is being pulled by a horizontal spring with a spring constant of 325N/m. The coefficient of kinetic friction between the lower block
klove1313
Hey, my teacher gave me these two problems for Homework and me nor anybody else in my class has no idea how to do them, any help would be greatly appreciated.
1. a 15.0kg block rests on a horizontal table and is attached to one end of a massless, horizontal spring. By pulling horizontally on the other end of the spring, someone causes the block to accelerate uniformly and readch a speed of 5m/s in .5s. In the process, the spring is stretched by .2m. The block is then pulled at a constant speed of 5m/s, during which time the spring is stretched by only .05m. Find (a) the spring constant of the spring and (b) the coefficient of kinetic friction between te block and the table.
Now i used F applied=-kx with F applied=ma and x=displacement of the spring i got the spring constand to be equal to -750. That is the farthest i got, i don't know if its right or even how to begin part b.
2.A 30.0kg blcok is resting on a flat horizontal table. ON top of this block is resting a a 15.0kg block, to which a horizontal spring is attached, as the drawing illustrates. The spring constant of the spring is 325N/m. The coefficient of kinetic friction between the lower block and the table is .6, while the coefficient of static friction between the two blocks is .900. A horizontal force is increading in such a way as to keep the blocks moving at a constant speed. At the point where the upper block begins to slip on the lower block determine (a) the amount by which the spring is compressed and (b) the magnitude of the force F.
I don't even know where to start any help would be greatly appreciated.
You got the spring constant right, although it is not negative. Regarding part (b), which forces are acting on the block during its constant velocity? Further on, the question which is always asked, what does constant velocity imply?
Constant velocity would imply that there is no acceleration and therefore the force applied and the friction would be equal. I do not however know how to get the coeficiant of friction. So would it be Force-Friction=0=kx?
Your equation does not make sense. It would make sense it you wrote something like ' Force - Friction = 0 '. The net force must equal zero, that part was good. Now, what does the force of friction equal?
I'm not sure this is where i get confused. If Force-friction= 0 then wouldn't the force of friction have to be equal to the force. But since there is no acceleration how do you find the force. and kx canot be equal to 0
As radou said, constant acceleration (i.e. a = 0) implies that the net force (i.e. the vector sum of all the forces) must be zero. So, the first step is to identify all the forces acting on the block. Since, we are only concerned with forces in the horizontal plane (friction etc) we can ignore any forces acting in the vertical plane.
well since the acceleration is zero that means that the friction would be equal to the force acting positively on the block. But how do i find what the friciton is equal to? it would be mu Force normal, but what is that equal to.
In solving this problem you'll need to set up two equations, one for each scenario: constant acceleration & zero acceleration.
This is incorrect. In Newton's 2nd law you need to use the net force, not just the force applied by the spring. You forgot to include friction.
"mu" is one of the two unknowns you are solving for, but what is the normal force? (What forces act vertically on the block?)
Again, to solve this problem and find "k" and "mu", apply Newton's 2nd law twice: once for the constant acceleration case, once for the constant velocity case. Solve those two equations together and you'll get your answers.
What is Simple Harmonic Motion (SHM)?
Simple Harmonic Motion is a type of oscillatory motion in which the restoring force is directly proportional to the displacement from equilibrium and the motion is periodic.
What is the equation for SHM?
The equation for SHM is x = A cos(ωt + φ), where x is the displacement from equilibrium, A is the amplitude, ω is the angular frequency, and φ is the phase angle.
How is the period of SHM calculated?
The period of SHM is the time it takes for one complete cycle of the motion and is calculated using the equation T = 2π/ω, where T is the period and ω is the angular frequency.
What is the relationship between the frequency and period of SHM?
The frequency of SHM is the number of cycles per unit time and is inversely proportional to the period. This means that as the frequency increases, the period decreases and vice versa.
How do we apply SHM in real-life situations?
SHM can be applied to various systems in nature and technology, such as pendulums, springs, and musical instruments. It can also be used to model the motion of particles and waves in physics.
