Help with theoretical density
perplexabot
I posted this in the engineering section but no replies : ( ... Let us see if the physicists can help.
Given: Density (D) of Si is 2.328 g/cm^3. Si has diamond crystal structure.
Find: Theoretical density of a single crystal of Si.
Theoretical density = m/V
I know mass = (number of atoms) x (mass of atom), in a diamond crystal structure there are: [(1/8) x 8] + [(1/2) x 6] + [(1) x 4] = 8 Si atoms/crystal structure
Now calculating volume is my issue, do I need the lattice constant? If so, how does one calculate it?
Or is it just V = (m x 8)/D = (m x 8)/2.328, where m = 28.1 amu converted to grams?
However, if I do that, I think I'll end up with the given density. What is the difference between the given density and theoretical density? Please help.
Thank you.
Answers and Replies
Simon Bridge
17,874
1,657
If the theory is very good - nothing. (Usually the "given" density will be some empirically determined value.)
For the lattice constant: what is the Si-Si bond length?
perplexabot
Hmm, that makes sense. Thank you for clearing that out.
Well using google the lattice constant for silicon is 5.43095 Angstroms at 300K. Should this constant be given in the problem? So the volume would be (5.43095 * 10^-8)^3 cm^3 ?
Simon Bridge
17,874
1,657
That is what it means all right.
Just looking up the lattice constant is a valid alternative to applying some theory to predict it ;)
perplexabot
Haha. Thank you. Finally, someone was able to help me out.
Suggested for: Help with theoretical density
  • Last Post
  • Last Post
  • Last Post
  • Last Post
