Convert y=3x into polar form: Step-by-Step Guide with Example | Learn Math
  • Thread starter popsquare
  • Tags
    Polar
In summary, the conversation discusses the process of converting the equation y=3x into its polar form by substituting x= r cos (theta) and y=r sin (theta). The solution is found to be r=0 or theta=1.249 radians. However, it is noted that this may not be the best way to graph a straight line in polar coordinates, which are better suited for curves.
popsquare
I have gotten from this equation: y=3x into its polar form by substituting
x= r cos (theta) and y=r sin (theta) to get me here:
r sin (theta) = 3r cos (theta) Substitute and simplify.
r sin (theta) - 3r cos (theta) = 0 Subtract 3r cos (theta) from both sides.
r [sin (theta) - 3 cos (theta)] = 0 Factor out r from the equation.
Now I set both equal to zero like this...
r = 0 or sin (theta) - 3 cos (theta) = 0
I am assuming r = 0 is included in the graph of the second equation. So the only solution to the original problem comes from solving the second equation for Theta --->
arctan (3) = 1.2490 radians
Is 1.2490 radians the correct solution to the original question of convert y=3x into polar form?
Mathematics news on Phys.org
That might be the right answer to the question of what angle is formed between the line y=3x and the x-axis, but just "1.2490 radians" isn't a polar form of anything, it's just a number. An answer like "theta=1.249" might look better, but keep in mind you're missing the half of the line that goes through the third quadrant (as traditionally r is taken to be non-negative)
Thanks for your help. Office Shredder. Are either of these possible as polar points
(0,1.249 rad) , (infinity, 1.249 rad)
because I am thinking since r = 0 it cannot possibly be a line like y=3x. Convert the radian angle I found into a polar point that extends infinitely into the I and III Quadrants like the rectangular line equation.
Remember that polar coordinates are not the best for graphing straight lines, they are better with curves.
you have, sin (theta) - 3 cos (theta) = 0. from here, you can get
sin (theta) = 3 cos (theta), divide both sides by cos (theta)
tan (theta) = 3
Now think about all the (r, theta) that satisfy this equation. Well no matter what the r is the tan of theta has to be equal to 3. So as long as the angle formed with the origin is 1.249 rad, then the point (r, theta) is valid. The set of all (r, theta) solutions is the same as your graph of y = 3x.
HTH
What is a polar equation?
A polar equation is a mathematical representation of a curve or shape in the polar coordinate system, where points are defined by a distance from the origin and an angle from a reference axis.
How do you convert a polar equation to rectangular coordinates?
To convert a polar equation to rectangular coordinates, use the following equations:
x = r * cos(θ)
y = r * sin(θ)
where r represents the distance from the origin and θ represents the angle from the reference axis.
What is the difference between a polar equation and a rectangular equation?
The main difference between a polar equation and a rectangular equation is the coordinate system they use. A polar equation uses the polar coordinate system, where points are defined by a distance and an angle. A rectangular equation uses the rectangular coordinate system, where points are defined by x and y coordinates.
What are some common shapes represented by polar equations?
Some common shapes represented by polar equations include circles, cardioids, limaçons, and roses. These shapes can have different variations depending on the specific polar equation used.
How can I graph a polar equation?
To graph a polar equation, plot points by substituting different values for the angle (θ) and distance (r) in the equation. Then, connect the points to create the curve or shape. Alternatively, you can use a graphing calculator or software to graph the equation for you.
  • General Math
  • General Math
  • General Math
  • General Math
