Homework Help: Help with vector physics problem
  1. Jan 24, 2008 #1
    Let vectors [tex]\vec{A}[/tex]=(2,1,-4) [tex]\vec{B}[/tex]=(-3, 0, 1), and [tex]\vec{C}[/tex]= (-1, -1, 2) .
    Calculate the following:
    What is the angle[tex]\theta_{AB}[/tex] between [tex]\overline{A}[/tex] and [tex]\overline{B}[/tex] ?
    2. Relevant equations
    [tex]\vec{A}[/tex] * [tex]\vec{B}[/tex]= magnitude of A * Magnitude of B * Cos[tex]\theta[/tex]
    magnitide of X= [tex]\sqrt{a^{2}+b^{2}+C^{2}}[/tex]
    3. The attempt at a solution
    magnitude of A= 4.58
    Magnitude of B= 3.16
    [tex]\theta[/tex]=arccos[( A * B)/ magnitude of A * magnitude of B)
    I tried that but the incorrect answer. Maybe i did the arithmetic wrong. Please Help..
  3. Jan 24, 2008 #2
    G01
    I can't tell you if you did the arithmetic wrong if you don't show your calculations...
    Also, it seems you posted this problem in the forum 3 times. Please do not flood the forum with repeat posts.
  4. Jan 24, 2008 #3
    sorry if i posted it three times. It is my first time using this program.
    magnitude of a= [tex]\sqrt{2^{2}+ 1^{2}+ 4^{2}}[/tex]= 4.58
    Magnitude of b= [tex]\sqrt{-3^{2}+ 1^{2}}[/tex]= 3.16
    and the vector A * the Vector B gives me -10
  5. Jan 24, 2008 #4
    G01
    OK, you calculations for the magnitudes are correct. Can you show me what you get for [tex]\theta[/tex] and the full calculation involved?
    I ask because you have the correct formula, so I think the error is probably in your calculation somewhere.
  6. Jan 24, 2008 #5
    a ha!!! i just saw my mistake!! But i will show you my calculations that i just re-did
    [tex]\theta[/tex][tex]_{AB}[/tex]= arccos[ -10/ (4.58* 3.16)]
    = arccos(-10/ 14.47)
    = 133.7
    Thanks a lot!!!
  7. Jan 24, 2008 #6
    I can't tell you the number of times I begin to spend the time typing up a problem here, and then all of a sudden I figure out the answer to my question.
  8. Jan 24, 2008 #7
    G01
    Good Job!
  9. Jan 25, 2008 #8
    i know i couldn't believe it! I was so frustrated trying the problem out over and over. I lauphed so hard when i figured it out lolz... I thought it was such a hard problem, turned out pretty easy
