Help with Y'=0 wanted
  • Thread starter jakobs
jakobs
I'm going to solve the equation Y'=0 if Y=x*e-0,4x
I can come as far as to Y'=(1-0,4x)*e-0,4x
Where do I go from here?
Can i just write (1-0,4x)*e-0,4x=0 ?
I can solve the easier kinds of these equations, but this one is the hardest of the ones that I have, and I suspect that something like this will show up on a test in the future, so it would be good if I can solve it.
Anyone can help me in the right direction?
Answers and Replies
drawar
132
Since [tex]{e^a}[/tex] is always > 0 for every value of a, then assume your computed y' is correct, you only need to solve the equation: 1-0.4x = 0, as simple as that.
8,699
Yes. Now, either 1 - 0.4x = 0 or e-.4x = 0.
Note that e-.4x ≠ 0 for any real x.
Edit: Didn't notice that drawar said essentially the same thing.
jakobs
So I only have to solve 1-0,4x=0 and that will be the whole answer for the whole equation?
CAF123
88
Well, the solution to 1-0.4x =0 solves Y'=0.
jakobs
I don't understand the whole thing :confused:
Can somebody show all steps to solving this one?
I really need to learn it.
8,699
No, we won't do your work for you, but we'll help you do it.
The problem, apparently, is to find the x value(s) for which f'(x) = 0, where f(x) = xe-.4x. (Changed from your notation of y(x) to f(x).)
You found f'(x) = (1 - 0.4x)e-.4x
If f'(x) = 0, then (1 - 0.4x)e-.4x.
For what x is f'(x) = 0?
jakobs
According to some earlier posts the solution to 1-0.4x =0 solves Y'=0
If x is 2.5 then it will be 0.
But what should I do with e-0,4x?
8,699
Nothing. As already mentioned, e-0.4x > 0 for all real x.
jakobs
Okay, so the answer to the problem is:
y=x*e-0,4x
y'=(1-0,4x)*e-0,4x
y'=(1-0,4x=0
x=2.5
e-0,4x is always >0
And this classifies as the correct answer?
8,699
y=x*e-0,4x
y'=(1-0,4x)*e-0,4x
y'=(1-0,4x=0
x=2.5
e-0,4x is always >0
You have a lot of cruft in there that is unnecessary. Here is all you need to say:
If y = x*e-0.4x, then y' = 0 when x = 2.5.
Suggested for: Help with Y'=0 wanted
  • Last Post
  • Last Post
