HELP: Work Done
  • Thread starter moimoi24
moimoi24
48
A box of weight 200N is pushed so that it moves at a steady speed alog a ramp, through a height of 1.5m. The ramp makes an angle of 30° with the ground. The frictional force on the box is 150N while the box is moving. What is the work doe by the person?
none
please explain this one.. thanks...
Answers and Replies
CAF123
88
What have you tried? The box moves at steady speed so its change in kinetic energy is zero. There are two forces acting on the box which tend to transfer energy away from the box. THe person must put this energy in to allow the box to continue to move with steady speed.
Draco27
54
Lets solve this one
now there is no acceleration in the block right??
So as velocity is constant, there is no force
So the forces must cancel out...
hope now u get it
moimoi24
48
i didnt get what you mean, sorry....
the answer is 750 J, but i am confused with the formula...
CAF123
88
Ok, you have identified the two forces transferring energy away from the block, right?
Compute the work done by those forces. (you should get negative values).
Therefore, if x amount of joules is transferred away then the person must provide that same number of joules into the system.
moimoi24
48
this is how i work on it:
Total Force
F = Wsin30 + fr
= 200 (1/2) + 150
= 250 N
then, the path distance is 3m
W = F(s)
= 250 (3)
= 750 J
moimoi24
48
Im just confused with the sin30 thing, why is it that formula? thanks a lot.
Draco27
54
Lemme try
now Frictional force =150N acting along the incline
and weight of the box acting along the incline = 200 *sin(30)=200*1/2=100N(weight*sin 30 gives us its weight along the incline and weight*cos 30 gives us weight perpendicular to incline)
So total force = 250 N along incline
so the man is also exerting a force of 250 N
now sin(30)=1.5/length of incline
so length of incline = 1.5 *2 =3m
so work done = 250*3 =750joules
Hope u got it now
moimoi24
48
Lemme try
Hope u got it now
thanks... i mean, why do we have to use sin30?
Draco27
54
Do u know any program that can be used to make drawings ??
moimoi24
48
what kind of drawing? autocad, paint, corel draw, photoshop....? please accept my friend invitation.. thanks...
azizlwl
1,065
Total work done=Conservation force x height + Non-conservative force x d.
W=mgh + Ffd
W=200x1.5 + 150 x 1.5/Sin30
W=300 + 450
W=750 J.
Draco27
54
http://i1168.photobucket.com/albums/r493/siddhant35/th_b1ef28a8.jpg
now i can explain(sry for that messy thing)
if u zoom u can see that mg is acting downward and can be resolved into 2 components
1 along the incline and other perpendicular to it...(indicated by red)
after resolving u can get mg in 2 parts
here mgsin30 is acting along incline and mg cos 30 is acting along the perpendicular
note that mgcos 30 is cancelled out by normal force exerted by block
so mg sin 30 remains
now friction also acts along incline
so add forces along incline to get the force applied by man
then proceed as said above
moimoi24
48
sorry but i cant see the image..
Draco27
54
Download and zoom silly
moimoi24
48
thanks a lot... its a great help... :)
Draco27
54
some other tips for such problems
note that if friction is not given but coefficient of friction is given
as u know frictional force = coefficient of friction*Normal force
Here normal force would be mg cos 30
But this is not need here as friction is already given
hope that helped
hoping to see u around....
moimoi24
48
please add me as your friend because i know i will still have lots of questions,,, thans for the help...
Suggested for: HELP: Work Done
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
