Concentration of salt in the tank
In summary, the conversation discusses the initial concentration of salt in a tank and the rate at which water with a higher concentration of salt flows in and is pumped out. The differential equations for the volume of water and concentration of salt are solved to find the particular solutions. The concentration of salt in the tank when it first overflows is 0.5 grams per liter.
sam_0017
Help... ?
A 200 liter tank initially contains 100 liters of water with a salt concentration of 0.1 grams per liter.
Water with a salt concentration of 0.5 grams per liter flows into the tank at a rate of 20 liters per
minute. Assume that the fluid is mixed instantaneously and that this well-mixed fluid is pumped out
at a rate of 10 liters per minute. Let c (t) and
v(t), be the concentration of salt and the volume of
water in the tank at time t (in minutes), respectively. Then,
v`(t)=10
v(t) c`(t) +20c(t)=10
a) Solve these differential equations to find the particular solutions for v(t) and c(t).
b) What is the concentration of salt in the tank when the tank first overflows?
v(0)= 100 L , c(0) = 0.1 gm/L , c(t)=0.5 gm/L
v`= 10 ==> v (t) = 10t + k
==> v(0) = 0 + k =100 ==> k=100
so : v(t) = 10 t + 100
(mass) m= c(t) * v(t)
m`=c`(t)v(t) + c(t) v`(t)
10 = c`(t)(10t+100)+ c(t) *10
c`(t) + c(t) (10/(10t+100)) = 10/(10t+100)
by solving this DE :
e^∫(1/ t+10) dx = t+10
Multiplying through by both sides gives:
(t+10)c`(t)+c(t)=1
∂/∂t{c(t) (t+10)} =1
==> by integral
c(t) ( t+ 10) = t
==> c(t) = t/(t+10) +k
c(0) = 0.1
0.1= 0 + k
so c(t) = t/(t+10) +0.1
a) v(t) = 10t + 100 and c(t)= t/(t+10) + 0.1b) The concentration of salt in the tank when the tank first overflows is 0.5 grams per liter.
1. What does "concentration of salt in the tank" mean?
The concentration of salt in the tank refers to the amount of salt dissolved in a given volume of water in the tank. It is typically measured in parts per million (ppm) or percentage (%).
2. How is the concentration of salt in the tank measured?
The concentration of salt in the tank can be measured using a variety of methods, such as a salinity refractometer, a saltwater test kit, or an electronic conductivity meter. Each method has its own level of accuracy and ease of use.
3. Why is it important to monitor the concentration of salt in the tank?
The concentration of salt in the tank is important to monitor because it directly affects the health and well-being of the aquatic organisms living in the tank. Too high or too low salt levels can be harmful and even fatal to the organisms.
4. What is the ideal concentration of salt in a tank for marine organisms?
The ideal concentration of salt in a tank for marine organisms varies depending on the specific species and their natural habitat. However, a general range of 30-40 ppt (parts per thousand) is considered suitable for most marine fish and invertebrates.
5. How can the concentration of salt in the tank be adjusted?
The concentration of salt in the tank can be adjusted by adding or removing saltwater, depending on the current concentration. It is important to follow proper procedures and use a reliable method of measurement to ensure the correct concentration is achieved.
