Hep-th papers on Monday
  1. May 29, 2006 #1
    Oriol Pujolas looks at the DGP model. If you don't know, the DGP model is
    a popular model among phenomenologists in which you have a
    five-dimensional gravity with a 3-brane in it, and the action contains
    both the bulk 5-dimensional Einstein-Hilbert term ("integral R.sqrt(-g)")
    as well as an additional 4-dimensional Einstein-Hilbert term that is stuck
    on the 3-brane. The latter term is unlikely to appear in string theory, I
    think. At distances shorter than a crossover scale - usually assumed to be
    the Hubble scale without a good reason - gravity looks 4-dimensional. At
    longer distances, the bulk term starts to dominate and gravity is
    5-dimensional. Pujolas studies quantum fluctuations in this model: the
    author computes some Green's functions, and a one-loop effective potential
    arising from the quantum fluctuations.
    J.C. Bueno Sanchez and K. Dimopoulos study a new kind of inflation based
    on a rolling scalar field - a quintessence. Although the picture is
    string-inspired, it does not seem that they are talking about a specific
    well-defined background in string theory. Their description of the
    "trapped quintessential inflation" has many stages and it reads like a
    novel. The first stage of their inflation starts in a steep potential,
    hypothetically generated by non-perturbative effects in string theory.
    Then you reach an ESP - enhanced symmetry point - where you produce a lot
    of light particles. They argue that this leads to a period of inflation
    which I don't quite understand; is a strong particle production compatible
    with inflation? At any rate, the scalar fields eventually leave the ESP
    point and go into another steep region, which gives you reheating. Then
    the scalars freeze because of cosmological friction. It is fixed for a
    long time until the present, when it starts to behave as a quintessence
    and roll towards vanishing vacuum energy. A pretty complicated picture
    combining many pieces that are popular. It seems that we don't have enough
    data to check each wheel and gear of the construction (and similar
    Rudnei Ramos and Marcus Pinto investigate phase transitions in certain
    non-relativistic field theories with a lot of scalar fields. They argue
    that they have proved a no-go theorem: the models of this kind, describing
    things like hard spheres, can exhibit neither inverse symmetry breaking
    (which means that a symmetry is broken at high temperatures instead of the
    usual low temperatures) nor symmetry non-restoration (which describes a
    situation in which the symmetry is not restored even at very high
    temperatures). Finally they focus on a specific model that includes a
    Bose-Einstein condensate in the phase diagram. There is no reentrant phase
    (an intermediate phase with a partial symmetry breaking) in this model,
    but they argue that other models might have it.
    Canoura, Edelstein, and Ramallo investigate the AdS/CFT correspondence
    with Sasaki-Einstein manifolds and additional D-branes. As you can see,
    that combines two concepts. One of them is the class of Sasaki-Einstein
    manifolds L^{a,b,c}. These manifolds have topology of "S2 x S3". The
    metric is rather complicated but for a choice of three positive integers
    "a,b,c", you can follow Cvetic, Lu, Page, Pope, as well as Martelli and
    Sparks, and construct a manifold whose topology is "S2 x S3" such that the
    cone constructed above this base is a Calabi-Yau space. The second
    ingredient of the paper are additional D-branes (referred to as "D-brane
    probles") added into the bulk. They add bulk open string degrees of
    freedom on the AdS side, and flavors on the CFT side. The paper may be
    viewed as Witten's construction of di-baryonic operators implemented in
    the case of the complicated Sasaki-Einstein manifolds replacing Witten's
    simple five-sphere.
    Alfonso Ramallo has another paper about a similar topic. He also adds
    D-branes in the AdS bulk. In fact, he wants to consider intersecting
    D-branes. Such D-branes generate new fields - flavors or "quarks" - in the
    dual gauge theory. Such "quarks" can form bound states - mesons. Ramallo
    claims to be able to compute the spectrum of such mesons in a rather
    general case where the D-branes can have rather general dimensions. He
    uses the quenched approximations - the D-branes are treated as probes.
    Anacleto, Nascimento, and Petrov study non-commutative field theories,
    especially their UV behavior. The particular theory they consider has a
    real scalar field with a quartic potential and a Dirac field coupled by a
    Yukawa term. They choose the "coherent state approach". It seems that it
    means that this allows them to make the propagators suppressed by
    "exp(-theta.p^2/2)" relatively to the propagators in the "ordinary"
    approach that are the same as in the commutative counterpart of the theory
    (because the kinetic term is the same). Using the Schwinger
    parameterization, they end up with an integral for the one-loop effective
    potential that clearly converges for nonzero values of the
    noncommutativity "theta": at high values of "t", the Schwinger parameter,
    the integrand is exponentially suppressed. Also, there is a cancellation
    whenever the quartic coupling and the Yukawa coupling are related to each
    other in a way that resembles the supersymmetric relation (even though in
    their particular theory, there is just one real boson field, and no SUSY).
    At any rate, I think that the nontrivial divergence structure only occurs
    at the two-loop level where you can see the UV-IR mixing and similar
    things, but they don't get that far, so I doubt that the experts in
    noncommutative field theory will be thrilled.
    Raphael Bousso tries to define a better probabilistic distribution for the
    landscape than anyone else, and he is approaching this problem in a
    typically Boussian i.e. holographic way. Recently we discussed Vilenkin's
    approach to the question of the probabilities on the landscape. They end
    up with a pile of ambiguous and contradictory mess, and Raphael is
    rightfully dissatisfied with these anthropic results. His first principle
    is that only one causal diamond should be looked at when you calculate the
    probabilities. This sounds correct to me because regions of spacetime
    behind a particular diamond could be complementary to the diamond itself:
    they may be described by the same degrees of freedom and you should not
    double-count them.
    His ultimate definition of the probability distribution is relatively
    simple. Consider the set of stable and unstable vacua that you want to
    include into your landscape game. Some of them are "terminal" (usually
    denoted "Z" in Bousso's paper) - and they don't decay. Others are unstable
    (labeled "A,B" etc.) and they do decay. Raphael looks at genealogy trees
    of these vacua. Each mother vacuum can decay to the daughter vacua, and
    Raphael only uses the "branching ratios" i.e. the probabilities that "A"
    decays to "B" or "Z". I hope that he knows how to calculate these
    dimensionless branching ratios from the instanton actions and vacuum
    energies but I don't see the rule in the paper. Instead, he focuses on the
    ultimate probability distribution for the vacua calculated from the
    branching ratios for the decay. It is virtually identical to Google's
    PageRank algorithm, as long as you replace hyperlinks between web pages by
    decay channels between vacua, and Raphael can obtain finite results for
    the probabilities (PageRank) of different vacua whenever there exists at
    least one available terminal vacuum. If it exists, small trees dominate
    Raphael's ensemble. Raphael does not say which vacua of string theory
    ultimately end up with the highest PageRank, but someone else could have
    an answer. I agree that Raphael's calculation is more justified than the
    random ad hoc anthropic prescriptions that various people want to apply to
    the eternal inflation, but I think that much more work is needed to
    extract useful information from Raphael's approach even if it is correct.
    E-mail: lumo@matfyz.cz fax: +1-617/496-0110 Web: http://lumo.matfyz.cz/
    eFax: +1-801/454-1858 work: +1-617/384-9488 home: +1-617/868-4487 (call)
    Webs: http://schwinger.harvard.edu/~motl/ [Broken] http://motls.blogspot.com/
Draft saved Draft deleted
