Hermitian Conjugate
pretty simple question. have to prove [itex]\hat{O} \hat{O}\dagger[/itex] is a Hermitian operator.
i found that
[itex]\left( \int \int \int \psi^{\star}(\vec{r}) \hat{O} \hat{O}^{\dagger} \phi(\vec{r}) d \tau \right)^{\star} = \int \int \int \phi^{\star}(\vec{r}) \hat{O}^{\dagger} \hat{O} \phi(\vec{r}) d \tau[/itex]
so all we need to get the result is to establish if the operator commutes with it's hermitian conjugate. i'm guessing it does but don't know why - can someone explain?
Answers and Replies
malawi_glenn
4,786
do you know how to use bra-ket notation? it is a bit easier then.
ok.
[itex] \langle \psi|\hat{O} \hat{O}^{\dagger}|\phi \rangle^{\star} = \langle \phi|\hat{O}^{\dagger} \hat{O}| \psi \rangle[/itex]
but then i again encounter the problem of showing that
[itex]\hat{O} \hat{O}^{\dagger}=\hat{O}^{\dagger} \hat{O}[/itex]
malawi_glenn
4,786
you are not using bra-ket correctly.
an operator is hermitian if <b|R|a> = <a|R|b>*
remeber to use dual-correspondence
sorry, i edited the bra-ket. now from the definition of hermition conjugate, O is hermitian iff
[itex]\hat{O}\hat{O}^{\dagger}=\hat{O}^{\dagger}\hat{O}[/itex]
malawi_glenn
4,786
have you used the dual correspondance and the fundamental property of inner product?
i don't know what those are. sorry...
malawi_glenn
4,786
ok, if you did not know what bra-ket is and how it works you should have said so....
yeah, well we use bra-kets in our course so i guess i'm supposed to know it. i just don't recognise the terms "dual correspondence" and "fundamental property of inner product", perhaps i do know them, just not by those names.
i tried googling them but to no avail...
malawi_glenn
4,786
here is a good introduction:
http://www.physics.unlv.edu/~bernard/phy721_99/tex_notes/node6.html
Now using integrals and wave functions:
Operator A is hermitian if:
[tex]
\int \psi _1 ^* (\hat{A} \psi _2 ) \, dx = \int (\hat{A}\psi _1 )^* \psi _2 \, dx
[/tex]
so we get
[tex]
\int \psi _1 ^* (\hat{O}\hat{O}^{\dagger} \psi _2 ) \, dx = \int (\hat{O}^{\dagger}\psi _1 )^* \hat{O}^{\dagger} \psi _2 \, dx [/tex]
verify that and continue
ok. im getting confused now.
my notes define hermitian conjugate as:
[itex](\int \psi^* \hat{O} \phi dx)^* = \int \phi^* \hat{O}^{\dagger} \psi dx[/itex]
the operator is hermitian if [itex]\hat{O}=\hat{O}^{\dagger}[/itex]
how does that compare to what you have?
is your definition just saying [itex]\hat{A}=\hat{A}^{\dagger}[/itex]
how would you write the first equation you wrote down in bra-ket notation?
malawi_glenn
4,786
https://www.physicsforums.com/attachment.php?attachmentid=13008&d=1205092708 [Broken]
page 53.
eq. 4.58. since expectation value is real. (4.57) so the opreator O there is hermitian if O dagger = O.
That is to say:
[tex]
\int \psi _1 ^* (\hat{O} \psi _2 ) \, dx = \int (\hat{O}\psi _1 )^* \psi _2 \, dx
[/tex]
If you want to do in bra-ket:
<b|O O^dagger |a> = <a|O O^dagger |b>* ??
consinder bra <b|O
DUAL is
O dagger |b>
Consider ket O^dagger |a>
DUAL is
<a| O
now use <r|t>* = <t|r>
all we need to do is put together the two duals you derived into a bra-ket to give
<a| O O(dagger) |b>
so we can now say
<a| O O(dagger) |b>* = <b| O O(dagger) |a> which implies a hermitian operator
is that ok?
out of interest, for getting it to work in terms of integrals,
i took the conjugate of the integral you wrote at the bottom left of post 10 but then got lost?
malawi_glenn
4,786
yes, that is correct done in bra-ket, as you saw, it was really easy.
[tex]
[/tex]
do this one more time.. recall that conjugating reverses the order (AB)* = B*A*
could we say
[itex](\int \psi^* \hat{O} \hat{O}^{\dagger} \phi dx)^*=(\int (\hat{O}^{\dagger} \psi)^* \hat{O}^{\dagger} \phi dx)^* = \int (\phi \hat{O}^{\dagger})^* \hat{O}^{\dagger} \psi dx = \int \phi^* \hat{O} \hat{O}^{\dagger} \psi dx[/itex]
so operator is hermitian?
when doing it in bra-ket notation, do you have to evaluate the bra and the ket dual seperately like you did or is it possible to do it all in one line?
malawi_glenn
4,786
you can of course say that the dual to O Odagger |a> is <a| O O dagger, then it is even more simple.
Yes, that is one other way that you can show it by using integrals and wave functions. Then you have been true to the definition in your course.
Related Threads on Hermitian Conjugate
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
