Hermitian Operators
  • Thread starter Lindsayyyy
Hi,
Let A and B be hermitian operators. Show that C=i[A,B] is hermitian aswell.
Well, I tried just to use the definition but I'm not sure if that's enough (my guess would be no lol).
[tex] C=i[A,B]=iAB-iBA=iA^\dagger B^\dagger-iB^\dagger A^\dagger =i[A^\dagger , B^\dagger ][/tex]
I'm not used to proof stuff as we don't learn it in my degree program.
Is that right, or is that a whole wrong approach?
Thanks for your help
Answers and Replies
117
[tex]C=i[A,B]=iAB-iBA = iA^{\dagger}B^{\dagger}- i B ^{\dagger} A^{\dagger}[/tex]
[tex]C^{\dagger}=(iAB-iBA)^{\dagger}[/tex]
Can you show that [itex]C[/itex] and [itex]C^{\dagger}[/itex] are the same?
I'd say:
[tex] C^\dagger = (iAB)^\dagger - (iBA)^\dagger = iA^\dagger B^\dagger-iB^\dagger A^\dagger [/tex]
117
Yup, so I guess you're done ;)
Thanks for the help, but is that really it?
I can't believe that actually because it looks so trivial.
I came to the conclusion that I could show aswell that the diagonal of the operator is real, but that would be much more of an afford I guess... ^^
Dick
26,263
619
I'd say:
You might want to give your reasoning behind that. It's easy to write down the correct answer for the wrong reason. What is [itex] (iAB)^\dagger[/itex]?
Hm I just used a calculation rule which says:
[tex] (AB)^\dagger = A^\dagger B^\dagger[/tex]
Fredrik
Staff Emeritus
415
I think Dick was more interested in how you dealt with the i. It looks like you know what you're doing, but your calculation in #3 doesn't show what you were thinking. In particular, you didn't make it clear that you understand that the first term on the left of the final equality is equal to the second term on the right. So it looked like you might have made two mistakes that cancel each other out.
Edit: As you can see in posts 13-14 below, I didn't even notice that the operators are in the wrong order on the right-hand side of the quoted equality. I used the correct rule myself, but I didn't see that you (Lindsayyyy) was using the wrong one.
Well, I don't know what to say now :blushing: . I thought it's allowed to factor out the i.
Fredrik
Staff Emeritus
415
If you just take it outside, both terms on the right in #3 would get the wrong sign.
I guess I did it wrong then. I don't know the right answer.
edit: hold on a second. I try something
[tex] C^\dagger = (iAB)^\dagger - (iBA)^\dagger = -iA^\dagger B^\dagger +iB^\dagger A^\dagger [/tex]
would that be right?
Fredrik
Staff Emeritus
415
No, you had the right answer the first time. It's true that $$(iAB)^\dagger - (iBA)^\dagger = iA^\dagger B^\dagger-iB^\dagger A^\dagger,$$ but if you want to show that you know what you're doing, you have to do the two terms separately:
\begin{align}
(iAB)^\dagger &=-i(AB)^\dagger=-iB^\dagger A^\dagger\\
(-iBA)^\dagger &=i(BA)^\dagger =iA^\dagger B^\dagger.
\end{align}
vela
Staff Emeritus
Education Advisor
15,098
1,676
There is no such rule.
Fredrik
Staff Emeritus
415
Ahh...I didn't even see that the operators were in the wrong order on the right.
whoops, sorry. I didn't read the rule clearly. I have to drive home now, thanks for your help. I'll take a closer look tomorrow and post again if I need further help. :smile:
Fredrik
Staff Emeritus
415
It is now clear that you did make two mistakes that canceled each other out: You didn't change the order of the operators, and you didn't take the complex conjugate of the i.
Related Threads on Hermitian Operators
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
