Hex to Oct
  • Thread starter WaterRain
Convert the hexadecimal (base 16) value FACE.BE into octal (base 8), correct
to 2 octal places.
Nil
First, I've converted the FACE.BE to decimals and I got 64206.742188
Next I change them to octal
64206(dec) = 175316(oct)
However, I'm unsure with the 0.742188
I continued my solution by treating it is 742188 and got 2651454
If that's the case, my answer is 175316.27(oct).
Is this answer correct?
Any quicker way to do it like Octal to Hexadecimal without the need to convert into Decimal first.
Answers and Replies
I realized I made a mistake.
0.742188 should give 0.574 instead.
1. Answer is 175316.57?
2. Any quicker way to convert from Hex to Oct?
mgb_phys
7,819
Yes, each hex digit is two octal digits.
Take the hex digit, if it is less than 8 it's already octal - just put an 0 in front.
If it's more than 8, subtract 8, and put a 1 in front of the result.
eg. F = 1 7 ( ie 1*8 + 7)
It would be relatively easy if you convert hex into binary (1 hex digit gives 4 digits of binary) and then regrouping the resulting number 3 digits at a time to make octal digits, starting from the decimal point.
Your answer for the integral part is correct, but you can confirm it using the binary conversion.
The fractional part is represented by fractions, for example:
0.123= 1/10 + 2/100 + 3/1000 (in decimal)
So
0.BE = B/16 + E/256 (in hex)
(Yes, 0.BE (hex) gives 0.574 (octal))
and
0.257 = 2/8 + 5/64 + 7/512 (in Octal)
The procedure of grouping 3 binary digits to represent octal digits for the fractional part is the same as in the integral part, namely you must start the grouping from the decimal point towards the right, and pad remaining digits with zeroes if the number of non-zero digits to the right of the decimal (or rather octal) point is not divisible by 3.
Does this only work for a single Hex?
A hex digit is actually 4/3 of an octal digit. So for example, FFF hex = 7777 octal.
The best way to see this is to convert hex to binary, then binary to octal.
So
and
I get it now - partially.
FACE = 1111 1010 1100 1110
regroup = 001 111 101 011 001 110
Oct = 175316
But for .BE, it is not possible to do likewise but to use the method you suggest
0.BE = B/16 + E/256
Is this right?
I see. This means if converting a single hex I can use as mgb_phys suggested right?
example F(hex) = 17(oct).
Anything more than one hex will not work.
Like FFF(hex) = 7777(oct).
For one hex digit, and if it's to the left of the radix point -- yes, mgb_phys's method works. But why have two methods? The "write hex in binary and regroup to octal" method that mathmate outlines will work for any number of digits, and is easy to apply on both sides of the radix point (just remember to pad 0s away from the radix point).
Oct = 175316
0.BE = B/16 + E/256
Is this right?
Just to be clear, let's spell out the whole solution, using the regroup method for the entire number (you got the integer part -- I'm just adding the fractional part):
FACE.BE = 1111 1010 1100 1110.1011 1110
regroup = 001 111 101 011 001 110.101 111 100
Oct = 175316.574
Oct = 175316.574
Thanks DoctorBinary. I fully understand where my mistake is now.
.BE = .1011 1110
regroup = .010 111 110
Oct = .276
That's why I thought we can't apply the same to the fractional part. But now I got it.
Thanks to mgb_phys and mathmate as well :)
mgb_phys
7,819
It's worth noting that the figures to the right of the decimal point are only used in maths HW questions.
Sorry for my confusion on the fractional part - in computers real numbers are stored as IEEE floating point format.
.BE = .1011 1110
Oct = .276
Hmm, seems like you've taken a step backwards. Why did you rewrite the fractional part? The way I had it was correct:
.BE = .1011 1110
regroup = .101 111 100
Oct = .574
To the right of the radix point you pad the 0s to the right, not left!
I got it. I was showing what I did earlier which resulted in my mistake :)
Related Threads on Hex to Oct
10K
  • Last Post
22K
9K
  • Last Post
  • Last Post
9K
