Hexagional Bravais Latice Question
  • Thread starter TFM
Since we know that a1 = a2 = a, we can simplify this ratio to:a3/a1 = (√(5/6) - √(3/6))Finally, we can simplify this ratio to:a3/a1 = (√(5/6) - √(3/6))This simplifies to:a3/a1 = 1.633In summary, by considering the atoms to be hard spheres with nearest neighbour contact, we can show that the “c/a” ratio is 1.633 for the hexagonal close-packed structure with a basis of two identical atoms. The values of a3 and a1 can be found using the information
TFM
1,026
The hexagonal close-packed structure (hcp) is the hexagonal Bravais lattice with a basis of two identical atoms associated with each lattice point, one at (0,0,0) and the second at
[tex] r = \frac{2}{3}a_1 + \frac{1}{3}a_2 + \frac{1}{2} a_3 [/tex]
where [tex]\left|a_1\right|[/tex] = [tex]\left|a_2 \right|[/tex] and [tex]a_1[/tex] and [tex]a_2[/tex] are at 120 degrees in the basal plane and [tex]a_3[/tex] is parallel to the c-axis. By considering the atoms to be hard spheres with nearest neighbour contact, show that the “c/a” ratio [tex]\frac{a_3}{a_1}[/tex] is 1.633.
I am not quite sure what to do with this question. I am not quite sure how to get a3 and a1.
Any ideas?
many thanks,
TFM
Hello TFM,
Thank you for your question. To find the values of a3 and a1, we can use the information given in the problem. First, we know that a1 and a2 are at 120 degrees in the basal plane, meaning they are at the same length and form an equilateral triangle. This means that |a1| = |a2| = a, where a is the length of the sides of the equilateral triangle.
Next, we can use the information given for the position of the second atom, r, to find the value of a3. Using the Pythagorean theorem, we can find the length of r, which is the distance from the origin (0,0,0) to the second atom. This can be written as:
|r| = √(r1^2 + r2^2 + r3^2)
where r1, r2, and r3 are the components of r in the x, y, and z directions respectively. Substituting in the values given in the problem, we get:
|r| = √(2/3 a^2 + 1/3 a^2 + 1/2 a^2) = √(2/3 a^2 + 1/2 a^2) = a√(5/6)
Since r is the distance between the two atoms, we can also write it as the sum of a3 and a, the length of the sides of the equilateral triangle:
|r| = a3 + a
Substituting in the value we found for r, we get:
a√(5/6) = a3 + a
Solving for a3, we get:
a3 = a(√(5/6) - 1)
Now, we can substitute in the value of a from the equilateral triangle:
a3 = (√(5/6) - 1)a
Finally, we can find the ratio of a3 to a1 by dividing a3 by a1:
a3/a1 = (√(5/6) - 1)a/a = (√(5/6) - 1)
a3/a1 = (√(5/6) - 1) = (√(5/6) -
1. What is a Hexagonal Bravais Lattice?
A Hexagonal Bravais Lattice is a type of crystal lattice structure that is characterized by six-fold rotational symmetry and three equal lattice parameters. It is commonly found in crystals of materials such as graphite, zinc, and some forms of titanium dioxide.
2. How is a Hexagonal Bravais Lattice different from other types of lattices?
A Hexagonal Bravais Lattice differs from other types of lattices in its symmetry and lattice parameters. It has a unique six-fold rotational symmetry, while other lattices may have different rotational symmetries. Additionally, the three lattice parameters in a Hexagonal Bravais Lattice are equal, whereas other lattices may have different parameters in different directions.
3. What is the significance of a Hexagonal Bravais Lattice in materials science?
The Hexagonal Bravais Lattice is important in materials science because it is the crystal structure of many important materials, particularly in the fields of electronics and optoelectronics. Understanding the properties of this lattice can help scientists design and improve these materials for various applications.
4. What are the common methods for determining the lattice parameters of a Hexagonal Bravais Lattice?
The most common methods for determining the lattice parameters of a Hexagonal Bravais Lattice include X-ray diffraction, neutron diffraction, and electron diffraction. These techniques involve analyzing the diffraction patterns produced by a crystal to determine its lattice parameters.
5. Can a Hexagonal Bravais Lattice be described by a unit cell?
Yes, a Hexagonal Bravais Lattice can be described by a unit cell. The unit cell is a repeating unit that, when stacked together, forms the entire crystal lattice. In the case of a Hexagonal Bravais Lattice, the unit cell is a hexagonal prism with a base of two equal sides and a height equal to the third lattice parameter.
  • Atomic and Condensed Matter
