Higgs decay to 2 top quarks
In summary, there is no reason to believe that a very off-shell Higgs boson decay to 2 top quarks is not possible, but it is very unlikely due to the large background noise.f
Hello! I haven't really seen a feynman diagram with a higgs boson decaying to a top-anti top quark pair. The mass of a top pair is much higher than the Higgs mass on shell, but is there any reason why we can't have a Higgs boson (very) off-shell decay to 2 top quarks. The probability of that happening must be quite low, but is there any reason to not happen at all? Thank you!
How do you make this very off-shell Higgs boson? You seem to be confusing the Higgs being off-shell with the top being off-shell.
When you calculate the amplitude for a process like ##q\bar{q}\to t\bar{t}##, where the q's should stand for any light quarks in the proton, then you also have a tree-level diagram with only one Higgs-propagator, that contributes to the full amplitude (though it will be strongly suppressed).
But you would usually not call this a "Higgs decay".
We only call processes "decays" if the parent particle is real, i.e. on-shell (within its decay width of course).
Technically the process via a virtual Higgs goes into the top pair production cross section, in practice it's completely negligible as you can produce them directly from two gluons.
People do look for s-channel virtual Higgs bosons elsewhere, for example in the two photon or four lepton final states, as this cross section is related to the Higgs width. Here is a CMS measurement for example.
I am not sure I understand what you mean. If you produce an off shell higgs boson with a ##q^2 = 2 m_t##, the higgs can in principle decay to 2 on shell top quarks. Isn't that right? I am not sure what you mean by off-shell top in this case.
Thanks a lot! Right, it is not really a decay, I was just wondering if it can happen at all (even if strongly suppressed). This answered my question.
Everything that is possible can happen, but it will be supressed due to two top-propagators and phase space of at least 4 particles. Also, the background would be huge, considering the amount of top and anti-tops being produced from gluon-gluon fusion etc without an intermediate Higgs... Your signal would be completely blurred
Suggested for: Higgs decay to 2 top quarks
