Higgs Field Radio: Revolutionizing Global Communication
In summary, the higgs field and temperature field of the atmosphere are both scalar fields, but using the higgs field for 2-way communication radio would require the use of higgs particle excitations, which are not suitable for long-range signals.
bluecap
396
The higgs field is everywhere.. how do you use it in a 2 way communication radio so the United States can communicate with the other side of the planet by passing right thru the mantle and core without using any satellite relay station?
You don't.
The temperature field of the atmosphere is everywhere too. Doesn't mean you can use it as a radio either.
Likes ohwilleke
Vanadium 50 said:
You don't.
What is the connection of the temperature field of the atmosphere to the higgs field?
They are both fields.
Likes vanhees71
More specifically, they are both scalar fields.
Likes vanhees71
You'd need to use an _excitation_ of the field to send signals. For example, photons are _excitation_ of the EM field, and radios emit very large numbers of low-energy photons - that's what radio signals *are*.
Higgs field excitations are Higgs particles. Their properties are utterly unsuitable for sending long-range signals.
1. What is the Higgs Field Radio?
The Higgs Field Radio is a revolutionary technology that uses the Higgs field, a fundamental field in physics, to transmit and receive radio signals. It allows for faster, more efficient, and more reliable global communication.
2. How does the Higgs Field Radio work?
The Higgs Field Radio works by using the Higgs field to create tiny vibrations, or ripples, in spacetime. These ripples carry radio waves, which can then be received and decoded by a receiver. This process allows for communication to occur without the need for traditional radio towers and satellites.
3. What are the benefits of using the Higgs Field Radio?
Using the Higgs Field Radio has numerous benefits, including faster transmission speeds, increased bandwidth, and improved reliability. It also has the potential to greatly reduce the cost and environmental impact of traditional communication methods.
4. Is the Higgs Field Radio currently in use?
No, the Higgs Field Radio is still in the research and development phase. However, numerous experiments and simulations have shown promising results, and it is expected to become a viable technology in the near future.
5. Are there any potential drawbacks or limitations to the Higgs Field Radio?
As with any new technology, there are still some limitations and potential drawbacks to the Higgs Field Radio. For example, it may require specialized equipment and infrastructure to be implemented, and it may have limited range compared to traditional methods. However, ongoing research and development aim to address these challenges and make the Higgs Field Radio a practical and widespread technology.
  • Beyond the Standard Models
